Handling of O2 Sensor
Hello,
In the spring I am planning on installing the Dansk pre-muffler that's sitting in the basement. I have never performed any exhaust work (or much of any other car-related work) and have a question about handling the O2 sensor. Once it's removed is there any special way to handle it as to not screw it up (other than dropping it or letting my 3 year old son throw it)? This is unknown territory for me and I'm thinking that I'll want to clean it up nice before I thread it into the silencer (I'm sure it has a soot layer on it after 36,000 miles) Is this advisable? Thanks for your advice, Last edited by KatoKato; 03-21-2005 at 04:04 PM.. |
I believe the 02 sensor should be replaced every 30K miles....
Replace it...
The Fox Carrera |
They typically last over 60k miles.....
Don't touch the sensor end and don't let it come into contact with oils or silicone..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil's advice is right on. You can use the OEM replacement, which is a bit spendy, or a generic unit and then graft the plug from the old one to the new one. I bought the generic unit, spliced the wires, soldered them, and then covered them with heat shrink tubing.
1984 Targa |
Recreational User
It's spring now, so get busy!
Anyone know of a distrutor that I could buy this part from and have it shipped to Canada? Thanks, |
And contrary to popular belief, Carrera's should NOT have an idle surge....(if all components and vac. etc is up to snuff)
The Fox Carrera Last edited by kqw; 03-22-2005 at 04:25 PM.. |
