Window switch help
I am having difficulty in getting the passenger side window down or up. The drivers side works fine and I know the passenger side works as the local shop applied power to it to roll it up but I'm not sure how they did this. The current setup is one switch on the drivers side and one on the passenger side. The second switch on the drivers side has been removed. A picture is worth a thousand words but if somebody could explain which wires go where as maybe the wires are incorrect? Thanks for any and all help!
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Here is the wiring for the '86. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-23-2010 at 04:40 PM.. |
1982 911 SC
Sorry about that as that pretty important info! Thanks again. |
I think you might need to jumper the 5-2 and 1-3 spade connectors.
Well, I tried connecting the known working switch on both the drivers and passenger side connections and no luck. So now I know there is no power getting to the passenger side motor. It can't be the ground since they share the brn ground wire. So, if jumping is the answer then I can just solder a jumper wire from (5 on Drivers switch) to (2 on Pass switch) and (1 on drivers switch) to (3 on Pass switch) using connections on Drivers side door only. Would this be correct?
In my head it sounds like if jumping would work then why would just hooking up a switch work which basically does the same thing???
'82 911 SC track car - SOLD '86 944 NA - SOLD '01 Boxster S |
sometimes the passenger side of mine wont go up or down from the switch from the drivers side, I just have to toutch the switch on the passenger side a bit and the driver's side control works again...
go figure
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-22-2010 at 09:30 AM.. |
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
best image I can find
Rick 88 Cab |
This is what makes solving this tricky. Assuming this modification was done by a PO and you have no documentation on the what was changed you need to start tracing the wires. Since the power goes through the passenger window switch on the DS if that switch was simply removed you won't have any power to the switch on the PS. Start by checking all of the wires on the PS to see if any of them have 12V. If not you need to check the DS to see if there was any attempt to bypass the switch and if those connections have come apart. You can see pretty clearly in the diagram from the link Crustychief posted that the wires on pins 1 & 3 and on 2 & 5 should have been connected to get the power to PS switch.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Senior Member
Since you will want to clean the old grease off the scissor X that lifts the glass (the regulator) anyways you should pull the panel (easy to do) and get that taken care of. Both sides cleaned and relubed since this would also allow installation of the doorstop reinforcement kit or at the least your chance to see how far the door(s) has torn to date.
Old grease buildup is a prime reason for blown fuses and motors that appear weak or even dead. Your situation sounds like a PO update but allthesame this is a very smart move. Finally, do vaccum and lightly grease the lowermost portion of the door and ensure that all round plugs are in place at the bottom - this is a common location for wind noise entering the cabin. Hope I don't sound like an Eyeore but you will be AMAZED at the difference in speed when you clean the reg. and connections should they be corroded at all.
'78 Targa in Minerva Blue |
Thanks so much for all the help so far. Temperarily I will just provide a 12v power source to roll the window up and down. Do I apply the +12V to the blu or blu/blk (1 or 2). I will still try to figure this out though.
The DS switch would not work for the PS window so maybe the connection is bad?
'82 911 SC track car - SOLD '86 944 NA - SOLD '01 Boxster S Last edited by dsmithwc04; 06-22-2010 at 10:08 AM.. |
Oh, and another thing. If I'm using a little portable 12v battery do I need to ground it to the car?
If your former battery has been removed, the new one must be connected to the car in the same manner. Do not connect them in series or parallel!
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Make sure it is disconnected from the rest of the car, as in current goes into the motor and directly back into the battery. your car the wires to the motor might be green and black.
Rick 88 Cab |
Well, so far the best method available is to jump the power from the battery to the wires where the switch used to be on the passenger side. Works enough for me not to worry about running a hot wire to the switch so it will work without a jumper.
