Jupiter 911
bklyn's Avatar
Strut bar purchase!
Gents, purchased my new after market front tower strut bar today from our host and got my free 1/43 model to boot! How can I avoid a wheel alignment after I install it? Or will a alignment be needed. I had an alignment when I put new tires on very recently, hate to do it again
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 04-17-2009, 01:43 PM
gtc gtc is offline
abides.
gtc's Avatar
It depends what model strut bar you purchased.
Mine is a Brey Krause part, which attaches with the two rear bolts. If yours is similar (and many are) you can carefully loosen the bolts and attach the brackets without shifting your strut and losing your alignment. There will still be one bolt holding the strut in place while you work. Just try not to lean on the fender while you work.
Graham
1984 Carrera Targa
Old 04-17-2009, 05:19 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the torque (35lbs.) on the front bolts to insure that it won't pop out of alignment when you loosen the rear bolts.
Just do one side at a time and you should be good.
If I may suggest, get new lock washers, once used they do not hold too well.
Great thing about the strut bar is that if you ever need to align it yourself, the bar's adjustment feature helps the adjustments needed.
'85 Carrera Targa
PCA/POC
Old 04-17-2009, 08:20 PM
3.2Carrera's Avatar
I put a strut bar in my car about a year ago(Along with a proper alignment and corner balancing) and what a difference, your going to enjoy it!!
-Joey B.-
1985 Carrera
http://www.pelicanparts.com/gallery/3.2carrera
Old 04-17-2009, 09:21 PM
Jupiter 911
bklyn's Avatar
Thanks guys, the information about the bolts and not to lean on the fenders I did not know, I will let you know how I make out.
Old 04-18-2009, 04:44 AM
DRACO A5OG's Avatar
Remember get the OEM Lock Washers. It is the ones with teeth. Concaved facing up, like a cup.
'85 Carrera Targa
PCA/POC
Old 04-18-2009, 10:50 AM
