HarryD's Avatar
Originally posted by pwd72s
Harry? You & I use the same method...I usually recruit Cindy to pour the gear oil while I'm under the car. I call it the "Cindy pour" method. "Cindy, pour...OK, stop"....repeat phrase as needed .
I like your addition of the ladder though...will try that next time.
Paul,
I hate to admit it but the picture is not mine but another Pelican 's. I do use the method tho but didn't have a pic so I "borrowed" his.
You are a brave man doing it with your lady. I read and heed the government warnings on the cans that clearly states: "Working on your car with the assistance of your lady may result in divorce or other forms of death.".
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-26-2005, 01:53 PM
randywebb's Avatar
Congrats.... Now what sort of guy would know to use the name Kelly clamps??
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-26-2005, 02:44 PM
SIR70T's Avatar
Harry and Paul,
I used the ladder method the other weekend and it worked a treat!!!
One other tip is once you are done, place the tub back into the oil dispenser for a couple of days until you tube is completely drained...
cheers
Shane
SIR70T
1970 911 T Australian Delivered
TYP901 Club Australia Founding Member
Old 03-26-2005, 06:20 PM
I can see the ladder falling or gear oil falling on the car resulting in much grief. I simply use a hand pump dispenser (STALUBE gear oil once came in a 1 liter container with a dispenser nozzle hooked to a clear plastic tubing about a foot long. ) Mobil 1 gear oil comes in a 1 liter container with a nozzle that you can slip a clear vinyl tubing from Home Depot and slip the end of the hose into the filler and invert the bottle and squeeze the gear oil out via the tubing.
Old 03-27-2005, 05:29 PM
yeuporsch's Avatar
An aside question. Is there a replacement gasket for the shift cover? Mine is springing a slow leak on the transmission fluid.
Thanks,
John
Old 03-28-2005, 07:03 AM
pookie's Avatar
The picture of the ladder would have been wonderful when I started this project. Of course the wife method would have been good too. I borrowed the tool from a neighbor and when he gave it to me he said here use these "kelly clamps" I said don't you mean roach clip? And was told that they were really called kelly clamps, who knew. Also I figured if this happened to someone else and they had to go buy a set of these, it would be pretty comical for them to be in sears or lowes asking to buy a roach clip. I'm now saying they couldn't but I would love to see the clerks face.
Thanks again for all the help.
1976 911 S Targa 3.2
Old 03-28-2005, 07:37 AM
