Hendog's Avatar
Should I drain the entire brake system?
I plan on rebuilding my brake calipers tomorrow. I will also change the rubber brake lines, change bleeder valves with speed-bleeders, and bleed the clutch. Should I start with opening the bleeder valves and draining as much out as I can then do the work? Is there any reason why I would keep any of the old fluid in only to bleed it all out at the end? If I keep as much fluid in the sytem as I do the work, will this minimize the chance of getting air in the sytem when bleeding?
Your experiences are appreciated.
Henri
'87 Carrera coupe: Venetian blue
Old 03-24-2005, 07:58 AM
IROC's Avatar
Don't drain it - just go about your upgrades and bleed the whole system whgen you're done. Like you suspect, this will mitigate the chances of getting any air in the system...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-24-2005, 08:06 AM
Hendog's Avatar
Thanks Mike. Another persons' opinion helps those of us who haven't done these things before.
Henri
Old 03-24-2005, 08:18 AM
Home of the Whopper
Use a different color brake fluid. That way you can see when you get all the old stuff out.
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 03-24-2005, 09:14 AM
jluetjen's Avatar
Whatever you do, don't drain the system dry because it's a real pain in the neck to refill the system. You'll need to bench-bleed the master cylinder if you do.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-24-2005, 10:36 AM
911mot's Avatar
Open the front caliper bleed nipples and use a length of wood wedged against the seat to hold the brake pedal in the full down position. This will stop any fluid dripping out as you work on it and will minimise the amount of air you have to remove when bleeding. Attatch pipes to the bleed nipples or cover with large lumps of rag before you do this to avoid brake fluid spraying everywhere.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 03-24-2005, 10:45 AM
Hendog's Avatar
What size tubing is required to fit over the bleed nipples?
Henri
Old 03-24-2005, 11:17 AM
911mot's Avatar
Small rubber like vacuum hose. Route into a bottle. Leave hoses attatched until youve squeezed the pistons back.
1984 3.2 Carrera
Old 03-24-2005, 11:26 AM
