Alternator Brushes- what is the minimum length?
Hello,
my alternator light is (lightly) shining when the engine is running 2500+ revs in my 1975 911s. It is not the voltage regulator (already replaced it). According to the 101 projects the alternator itself might be the problem. I opened it and I could change the brushes, if this should be the root cause. Is my assumption correct? What is the minimum length of the brushes? Regards, wullie
1975 911s Silver Anniversary Edition |
Brushes have to long enough to make contact with the slip ring under a slight "spring push" basis....
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Senior Member
If you have the brushes out, replace them! They are not that expensive and the most difficult part is getting to them.
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
