Nine9six's Avatar
Question H4 upgrade?
H4's for am 1987, 911...Will I need any mods to plug, relays, etc? What if I choose to run 80/100 watt blubs? Advantages/disadvantages?
Thanks in advance,
Paul
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-26-2005, 03:42 PM
Me like track days
Craig 930 RS's Avatar
Stick 'em in, ready to go.
As with all things Pelican, you will get a million different opinions - but I have the relay setup and used higher wattage bulbs....then went with lower wattage (55/60) bulbs and noticed little difference.
Get the P-n-P setup with 55/60 and be done with it - and enjoy the BIG difference!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-26-2005, 03:46 PM
Nine9six's Avatar
Thank you Craig, for the expedient response. I have a private party that is selling his H4's off his 86 Carrera. Any fitment issues from the 86 to 87? There doesnt seem to be, but before I spend the money, I would like to be sure.
Regards,
Paul
96 993 C2 (Current)
Old 03-26-2005, 03:54 PM
Me like track days
Nah, easy simple fit.
Just make certain you have the rings, 2 attach screws, and of course the housings & bulbs.
Are you CERTAIN they are H4s and not H5s??
His car (if U.S.) came with H5s -
Old 03-26-2005, 04:01 PM
KCPSG's Avatar
I had to get the adapter from our host for the H5 to H4. I could have gotten all new connectors from any local parts store but then I was worried about clearance issues in the headlight bucket.
I have noticed that the wires (right next to the plug are discoloring) so the Sucro kit is next...I am only running the standard wattage bulbs in there right now. So I know that when I get brighter lights there will be problems.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 03-26-2005, 04:34 PM
Me like track days
Oh whoa wait.......you have an '87. My mistake.
You WILL need adapters!
Old 03-26-2005, 04:37 PM
KCPSG's Avatar
here are some pics of the new adapter and the old plug I cut off to fit new adapter.
and here is the final w/the new H4's....It took about 10-15 min per light to install light and adapter
Phil
1998 BMW 328i
Old 03-26-2005, 04:39 PM
Nine9six's Avatar
Thanks for the photos Phil. I see what you mean on the discoloration of the wires. So will that be solved with a different relay? BTW, the black trim rings look sweet on your car. GP white?
96 993 C2 (Current)
Old 03-26-2005, 08:20 PM
I would use relays if you go with 800/100 watters.
With stock bulbs, relays are still a good idea, although I think not strictly necessary. The weak point in the lighting system seems to be the high/low beam switch. The failure of that switch is VERY common. But with stock headlights and no relays, it seems like the switch still goes for many years.
I used the Sucro relay, it's 25 bucks, really easy to install, easily reversed, and essentially invisible. I recently had to replace the high/low beam switch, while that is not that big of a deal, it is a $120 part.
That being said, is there really a big difference on the H5s that came on the 1987 cars, and H4s? They look basically the same.
Old 03-26-2005, 10:11 PM
Me like track days
H5s are amongst the worst headlights for a 911 - they have blobby, glare ridden light.
In 1999, I "upgraded" to a set of H5s......not knowing that most people get rid of them for H4s. They were nice & clear, as good as they could be - but still they stunk. The H4s are truly exceptional lights.
Old 03-27-2005, 09:46 AM
Team California
speeder's Avatar
He said that the seller's car is an '86, which came in the U.S. w/ DOT lights, not H5s. H5s began w/ the 1987 model year.
Denis
Old 03-27-2005, 09:58 AM
As Craig mentioned...the H4 and H5 plug pin-outs are different...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-27-2005, 11:14 AM
Nine9six's Avatar
Speeder,
Although it appears that I did not articulate my point as well as I should; the seller of the H4's, has an 86 Carrera. This is not to say that he has OEM lights in the car.
Due to an earlier post; and thanks to those who replied, I now can spot H4's upon a visual.
Yes Will, I can now see that from KCPSG's photos.
Happy Easter to all!
96 993 C2 (Current)
Old 03-27-2005, 12:10 PM
Team California
speeder's Avatar
I probably wasn't clear enough either, I was trying to say that an '86 would not have H5s, I'm sure that you are getting H4s. Happy Easter to you as well!
Denis
Old 03-27-2005, 02:06 PM
How can I tell which headlights I have ? I think my bulbs are replaceable not sure. Also My lenses seem cloudy any advice ?
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 03-27-2005, 03:10 PM
KCPSG's Avatar
H5's will have the little alignment "tits" on front of lens and the H4's should say H4 in the center (IIRC) of the lens and not have the alignment "tits"....both lights (H4's and H5's have replaceable bulbs) but the H5 is a sealed beam unit.
If your headlights are cloudy my bet is that you have H5's. Take the lights off and remove the bulb and use dish soap and water and rinse out. let them dry completly before re-installing the bulbs and mounting to car. otherwise they will fog again
Phil
1998 BMW 328i
Old 03-27-2005, 05:11 PM
KatoKato's Avatar
Originally posted by KCPSG
...and here is the final w/the new H4's....
I installed H4's on my 86' a few months back and had (still have) trouble getting the seals nice and tight along the mid-sections of the lights (top and bottom ok). Has anyone else had this problem?
Thanks,
Old 03-27-2005, 06:01 PM
