Source of clung - help required
After going over some railroad tracks the other week my car developed a "clung" which I assumed was the cv joints finally going bad. I have since replaced the joints but the sound remains. It has been hard to isolate if it is coming from rear or front. In fact sometimes seems like it is under the passenger seat.
Have also checked sway bar mounts and all seem entact. The clung is directly related to speed of car. I can hear it at very low speeds and it quickens as I accelerate. Thoughts are appreciated. Chris
Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie Last edited by ckmaggie; 03-27-2005 at 08:01 AM.. |
Bump - looking for some insight soon. I guess folks are enjoying Easter gatherings.
Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie |
Driving member
A few more details may be needed. Is the noise only present when the car is in motion?
If so you might try isolating it by taking the car out of gear while driving and let engine go to idle so as to hear the sound more clearly.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Yes, only when the car is in motion. When either in or out of gear. Almost like something is on my tire and as I move faster, it increase too.
Driving member
Desribe the sound a little better. Is it a clanging sound like metal against metal?
no metal sound. more of a dull thud (clunk). Like "thump, thump, thump". I can feel the vibration too. As I said before, feels like it is coming from passenger seat. But very hard to tell for sure.
Driving member
Could be just a tire our of balance. Make sure you don't have any foriegn objects in your tires.
RETIRED
Done any hard braking lately? Could be a flat spotted tire...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Crusty Conservative
How about a bubble on the inside sidewall of one of the rear tires? May have happened when you hit those rough tracks...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
tires seem ok. could flat spot or bubble be noticable upon visual inspection?
Driving member
If a bubble is on the inside wall of the tire it would be hard to see.
If you think it is on the passenger side it might be worth the effort to remove both wheels on that side and inspect everything thoroughly.
I am ruling out anything mechanical. Car runs absolutley fine when up to speed; no metal noise; strange handling, etc. I am thinking it is a flat spot. I have done some hard breaking of recent and I did see what looked like shaved rubber bits on one rear tire.
Question now is can I drive on it like this. Don't really want to buy new tires right now. I had the car out and sensation goes away at 40 + mph. Only really notice when I am in first or second gear, going slow. Thanks for all input thus far. Chris
RETIRED
Naw...it will just drive ya nuts.....are they Dunlop's by any chance? My SC hated those things....
Sway bar mount?
Rick 88 Carrera Targa -- There are only those that know and those that do not!!! -- |
Driving member
Well it is simple then. Just don't let get below 40
They are Dunlop SP 8000's. They have 12k on them.
I agree that it will drive me nuts but I'll have to deal until I get new tires. The sway bar mounts appear fine. Chris
Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie Last edited by ckmaggie; 03-27-2005 at 05:23 PM.. |
I liked the 8000s but the 750s are better.
Noise speeds up as the car does. Jack it up and rotate the wheels by hand. Loose railroad tracks can raise up as you cross them and damage an under carriage pretty good.
'80 SC |
