Chuck Moreland's Avatar
If you want to know how it works, tear it appart
I recently obtained this:
It is from an 83 coupe. Though I'm sure it would be cool upholstered and in the center of the living room, I think my wife would have a different perspective.
A portion of this will serve as a development-fixture for some future suspension components. But I sure don't need the whole thing.
Cutting the car apart is an interesting exercise. You get to see how it was built from the inside out.
If anyone has questions, wants something weighed, or wants to see some closeups of anything, speak up. Also if I've cutaway something you want, contact me.
Here is a picture of the door box section:
Cut away the quarters. The flares are not complete, probably not saleable so I may just use them to experiment - try my hand at creating some hand hammered flares.
The floor and rear shelf was taken out in one peice. It will provide a nice replacement, extending the life of some rust victim. I think it is already spoken for.
I will be weighing this and submitting that info into the offering plate of the church-of-light. It isn't that heavy.
These jams will probably find a nice home as rust repair panels:
Miscellaneous removed:
Here is the paydirt:
I'll be trimming this a bit further, but it should serve my purposes well. It should be a lot handier developing products on the bench than it is under a real car.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-27-2005, 03:05 PM
randywebb's Avatar
"It isn't that heavy."
- That is part of the body that PAG made of thin steel to save wt. in the RS and some others I think. It's never been clear to me how much wt. they saved that way....
BTW, folks who have cut apart the front door frames report that as time wnet on more steel appeared in those areas...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-27-2005, 03:36 PM
Kraftwerk's Avatar
Someone likes his sawz-all!
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 03-27-2005, 05:49 PM
Yes, Noah it's pretty gruesome. But the car it came from was accident damaged. Sniff.
And its demise will help others continue on - with donor parts and new products.
Randy, I still haven't popped it on the scale but it probably weighs 35-40 lbs. Note it has a section of the floor and rear window channel still attached. Definitely a bit heavier than I originally thought.
Old 03-27-2005, 06:09 PM
pwd72s's Avatar
Now I'm waiting for news of the product this brings about...
Old 03-27-2005, 06:18 PM
If any of that stuff dosen't get got, let us know out here!!!!
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 03-27-2005, 06:54 PM
Disbanded
juanbenae's Avatar
thats 1st shot would make for a good rikshaw (sp?).
Old 03-27-2005, 08:12 PM
One interesting thing is that some of the cavities are filled with a foam, sound deadener / vibration dampener. Other peices are not welded, but secured (glued) with caulk-line substance, or a sticky foam. Again for vibration dampening.
There is also paint on the back side of all the metal, inside the cavities.
Consider what happens to all this stuff if you have the tub dipped. All gone.
Another interesting thing is this carcass has been sitting out in the rain for weeks. Yet the cut edges of the metal are not showing even surface rust.
I realize the surface is galvanized, but I expect cut metal to show at least flash rust. None.
Old 03-27-2005, 08:54 PM
Allen Hall at www.alfaparts.net is looking for 911 sheetmetal to reproduce in his shop. Maybe some of those pieces, especially the rear seat and rear tray area, could be put to good use as forms before moving onto new cars. rlane had a thread awhile back showing the lower fender panel replacement Hall makes. I ordered the fender parts last week and he seems willing to try any piece someone sends his way.
Thanks for the post. Nothing like seeing the bones beneath the skin.
Scott
Old 03-27-2005, 10:27 PM
Chuck,
FWIW, here's how that piece looked at the factory in '71.
Sherwood
Old 03-27-2005, 11:07 PM
randywebb's Avatar
Interesting - I wonder when they started putting the foam sound deadener inside the panel cavities.
It seems like the later tubs must be somewhat heavier than the early tubs...
Old 03-27-2005, 11:19 PM
buster73's Avatar
Originally posted by randywebb
[B]Interesting - I wonder when they started putting the foam sound deadener inside the panel cavities.
Sound deadening and foam sounds lke mid to late 70's to me. Before nobody cared too much about noise. Not a great idea even with galvanized panels, but can be a nice surprise when you start welding. Remember always have a fire extinguisher ready.
Regards,
Guenter
73.5 911T, mod
Old 03-28-2005, 02:45 PM
I wish my rear frame sections were in as good as shape as the ones you have. I am in the process of putting in frame longitudinal repair panels on both sides. How much do you want for the door jambs?
1970 911T
XR400
93 F150
Old 03-28-2005, 04:05 PM
Shaun @ Tru6's Avatar
Chuck, you are nothing short of amazing!! I'll probably need whatever you are building for my 73!
BTW, I need one of these (circled in red). Let me know how much.
Tru6 Restoration & Design
Old 03-28-2005, 04:21 PM
Shaun, I'm guessing (hoping) you are joking. I'm not even sure what that piece is. Looks like a hunk of weatherstrip. I do know it went out in this AM's trash collection.
Old 03-28-2005, 04:38 PM
Zeke's Avatar
I have a cross section of the door sill and longitudinals from the Targa I cut up. I missed out big time by throwing the torsion tube away. I lot of people want to know more about the center of the thing. Now you can answer all those questions.
We should get together and compare the door sills. Mine was a '71. And it rusted on the cuts overnight.
Old 03-28-2005, 04:43 PM
doozer's Avatar
My standard answer when someone catches me cutting something up or knocking down a wall in the house by suprise ( long story) " The Beastie Boys made me do it!!"
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 03-28-2005, 04:47 PM
Milt, if you are coming to Monterey, bring it.
The torsion tube is interesting. The center spline section is common and open hole. No stops.
Chuck, yes, I was kidding. I've got tons of those things already.
Old 03-28-2005, 05:11 PM
Fascinating pictures. Somebody posted earlier something about, "So how much weight could they possibly have saved there?" In airplanes and racecars both, the the weight saving don't come from somebody saying, "Jeez, we could cut that off and save 20 pounds..." It's an ounce here and an ounce there, and eventually they add up to a quarter ton. Aluminum lugnuts, lightening holes, thin washers rather than thick, less paint rather than more...if it were easy, everybody woudl be doing it.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-28-2005, 05:12 PM
