-   -   WEVO..wow! (http://forums.pelicanparts.com/porsche-911-technical-forum/213626-wevo-wow.html)
rdane 03-29-2005 09:50 PM
WEVO..wow!
I have said it before, it is hard to out engineer even the 30 year old work of the Porsche design engineers.
Wevo is one of the few companies who consistantly does just that. The gate shifter and all its additional pieces were the first examples I had to play with. The new bearings and spring plates are the second.
As a guy who makes a living from his attention to detail in metal work I view these things as pieces of functional art. Sometimes you do actually get what you pay for.
These combined with Chuck's Elephant Racing poly-bronze bushings and mono balls should be an amazing torsion bar car.
http://forums.pelicanparts.com/uploa...1112161487.jpg
http://forums.pelicanparts.com/uploa...1112161564.jpg
http://forums.pelicanparts.com/uploa...1112161608.jpg
http://forums.pelicanparts.com/uploa...1112161653.jpg
Shuie 03-29-2005 09:55 PM
Damn! That guy can weld!
BigKenSteele 03-29-2005 09:56 PM
No mortal can weld like that...
(I think Shuie and I were typing at the same time)
911pcars 03-29-2005 09:56 PM
Beautiful. Too bad they're under the car.
Sherwood
rdane 03-29-2005 10:09 PM
Ya, I was thinking a robot on the welds...gotta ask Hayden. If not I want to kiss that dude's ring.
Jeff Alton 03-29-2005 11:29 PM
I like the details, The set screw that locks the adjuster bolt in place...
Those are purdy. Great looking stuff.
Jeff
Bob Goding 03-29-2005 11:54 PM
Thanks to Nostatic for these pics--Its Titanium too!
I have a Ti Colnago, for those that know,& the welds are nowhere
near as nice as this. Moots I think.http://forums.pelicanparts.com/uploa...1112169092.jpghttp://forums.pelicanparts.com/uploa...1112169146.jpg http://forums.pelicanparts.com/uploa...1112169178.jpg http://forums.pelicanparts.com/uploa...1112169222.jpg
rdane 03-30-2005 03:33 AM
http://www.moots.com/custom.php
http://www.moots.com/images/fr-rigormootis_sm.jpg
randywebb 03-30-2005 10:42 AM
Who is going to post a pic of an old Kelty pack frame?
911pcars 03-30-2005 10:52 AM
My LightSpeed frame has welds like that too. Must be a machine or a machine-like welding person.
Sherwood
mb911 03-30-2005 11:11 AM
They are you using Pulse tig to do that just so you know
Slider79SC 03-30-2005 12:07 PM
Rdane,
Do you have the Wevo internal gate system in your trans? I was thinking about installing one but wanted to hear from someone that has run it for a bit?
Thanks,
Cory M 03-30-2005 01:15 PM
All of the Moots and Litespeed (at least the Ti ones that are made in US)are welded by hand. There is a company called Merida that uses robots for welding their Al and Mg alloy frames. That's pic rdane posted is probably one of the most expensive single speeds you can buy. You should check out Ventana mountain bikes if you want to see some really nice Al welds, machine work, and beautiful powdercoat finishes. Cyclists have to be the most obsessive group around when it comes to weld aesthetics.
911Switzerland 03-30-2005 01:16 PM
Tey look cool.
Are they going on sale???
Thomas
Joeaksa 03-30-2005 01:18 PM
Thats aircraft/spacecraft quality welding. Works of art and nice to see!
I have a good friend who can hand weld sheets of aluminum foil together and it looks like the above. Works in the aerospace industry...
JoeA
mede8er 03-30-2005 01:18 PM
Talk about a 'roll of dimes'.....:eek:
rdane 03-30-2005 02:19 PM
I've had two 915 gear boxes with the complete WEVO set up. Worth the money IMO and anyone who has driven them.
This from Hayden, "welding is by hand, using a power rotary table to keep the part moving under the torch". That dude does nice work for you Hayden! The lock nut set up looks just as good and that too is by hand.
Craig 930 RS 03-30-2005 02:34 PM
Oh yeah......
WEVO...slam dunk baby....all great stuff.
Between him and Chuck....genius.
I have almost all WEVO except these plates.
You'd swear it was made for aircraft, Boeing that is.
Dane, can you highlight the advantages of this over the post-1978 factory adjustable springplates?
The man himself:
http://forums.pelicanparts.com/uploa...1112221984.jpg
The car he engineered at Daytona:
http://forums.pelicanparts.com/uploa...1112222028.jpg
89turbocabmike 03-30-2005 05:35 PM
That Is some beautiful welding but I've got to ask because it bothering me.
That set screw for the adjuster....it digs in(for lack of better description) to the adjuster to stop it moving right? Would it not damage the threads on the adjusting bolt which in turn would damage the housing threads when making re-adjustments depending on how far it was backed out or in? Part of the reason for these arms is to make frequent adjustments easier isn't it? I'm sure for street, most of us would just set and forget. Perhaps I'm missing something.
efhughes3 03-30-2005 07:46 PM
I would not imagine those being robotic welds, as the fixture costs and setup costs would need volume runs to justify.
