rdane's Avatar
WEVO..wow!
I have said it before, it is hard to out engineer even the 30 year old work of the Porsche design engineers.
Wevo is one of the few companies who consistantly does just that. The gate shifter and all its additional pieces were the first examples I had to play with. The new bearings and spring plates are the second.
As a guy who makes a living from his attention to detail in metal work I view these things as pieces of functional art. Sometimes you do actually get what you pay for.
These combined with Chuck's Elephant Racing poly-bronze bushings and mono balls should be an amazing torsion bar car.
Old 03-29-2005, 09:50 PM
Licensed User
Shuie's Avatar
Damn! That guy can weld!
Old 03-29-2005, 09:55 PM
BigKenSteele's Avatar
No mortal can weld like that...
(I think Shuie and I were typing at the same time)
BKS
Cars
-n-
Stuff
Old 03-29-2005, 09:56 PM
Beautiful. Too bad they're under the car.
Sherwood
rdane's Avatar
Ya, I was thinking a robot on the welds...gotta ask Hayden. If not I want to kiss that dude's ring.
Old 03-29-2005, 10:09 PM
Jeff Alton's Avatar
I like the details, The set screw that locks the adjuster bolt in place...
Those are purdy. Great looking stuff.
Jeff
www.turn3autosport.com
Old 03-29-2005, 11:29 PM
Thanks to Nostatic for these pics--Its Titanium too!
I have a Ti Colnago, for those that know,& the welds are nowhere
near as nice as this. Moots I think.
Old 03-29-2005, 11:54 PM
rdane's Avatar
http://www.moots.com/custom.php
Old 03-30-2005, 03:33 AM
randywebb's Avatar
Who is going to post a pic of an old Kelty pack frame?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-30-2005, 10:42 AM
My LightSpeed frame has welds like that too. Must be a machine or a machine-like welding person.
Sherwood
Old 03-30-2005, 10:52 AM
They are you using Pulse tig to do that just so you know
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-30-2005, 11:11 AM
Limbo
Slider79SC's Avatar
Rdane,
Do you have the Wevo internal gate system in your trans? I was thinking about installing one but wanted to hear from someone that has run it for a bit?
Thanks,
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 03-30-2005, 12:07 PM
Cory M's Avatar
All of the Moots and Litespeed (at least the Ti ones that are made in US)are welded by hand. There is a company called Merida that uses robots for welding their Al and Mg alloy frames. That's pic rdane posted is probably one of the most expensive single speeds you can buy. You should check out Ventana mountain bikes if you want to see some really nice Al welds, machine work, and beautiful powdercoat finishes. Cyclists have to be the most obsessive group around when it comes to weld aesthetics.
Old 03-30-2005, 01:15 PM
Tey look cool.
Are they going on sale???
Thomas
Old 03-30-2005, 01:16 PM
Senior Member
Thats aircraft/spacecraft quality welding. Works of art and nice to see!
I have a good friend who can hand weld sheets of aluminum foil together and it looks like the above. Works in the aerospace industry...
JoeA
Old 03-30-2005, 01:18 PM
Porsche Junky
mede8er's Avatar
Talk about a 'roll of dimes'.....
1986 930 RUF equipped
rdane's Avatar
I've had two 915 gear boxes with the complete WEVO set up. Worth the money IMO and anyone who has driven them.
This from Hayden, "welding is by hand, using a power rotary table to keep the part moving under the torch". That dude does nice work for you Hayden! The lock nut set up looks just as good and that too is by hand.
Old 03-30-2005, 02:19 PM
Me like track days
Craig 930 RS's Avatar
Oh yeah......
WEVO...slam dunk baby....all great stuff.
Between him and Chuck....genius.
I have almost all WEVO except these plates.
You'd swear it was made for aircraft, Boeing that is.
Dane, can you highlight the advantages of this over the post-1978 factory adjustable springplates?
The man himself:
The car he engineered at Daytona:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-30-2005, 02:34 PM
89turbocabmike's Avatar
That Is some beautiful welding but I've got to ask because it bothering me.
That set screw for the adjuster....it digs in(for lack of better description) to the adjuster to stop it moving right? Would it not damage the threads on the adjusting bolt which in turn would damage the housing threads when making re-adjustments depending on how far it was backed out or in? Part of the reason for these arms is to make frequent adjustments easier isn't it? I'm sure for street, most of us would just set and forget. Perhaps I'm missing something.
Old 03-30-2005, 05:35 PM
efhughes3's Avatar
I would not imagine those being robotic welds, as the fixture costs and setup costs would need volume runs to justify.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 03-30-2005, 07:46 PM
