My $5.00 trunk carpet "kit" (or something close to that)
Since I rebuild the motor, I no longer needed my 3ft. X 5ft. Vehicle and Utility Mat (Dynomat product), I purchased at Autozone back when.
So I found another use, I've been needing. Weighs hardly nothing:
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Not bad...going by the pic, I'd say it's pretty close to stock carpeting color!
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
, I'm calling it "charcoal"
isnt that stuff also good sound deadening?
Now if you could find a product to remove the pesky bush from the front bumper.........
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
I'm not here.
Good job! Looks good enough to pass my Concours test!
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
Senior Member
And how is it running??? Hope no leaks and finally the idle is where it should be?
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Also another description is it's running "clean", no smoking, no smoking at start up.
One other note, I'm actually going through adjustment of learning to not see leaks! Before the rebuild, besides all the grease, there was always considerable leaking both sitting and after driving.
Now none! It's a real physical energy saver, and I'm really having fun, cleaning the car up, weather is improving finally. Timing for all this has also worked out well. (Too look under and see everything dry is almost a dream into 4 years of the opposite)
