Source and Installation For CHT/EGT W/ Six-Position Switch
I'm thinking about installing a single CHT gauge and a single EGT gauge in my car, with probes on all six cylinders (sparkplug washer and probe in heat exchanger tubes). I would like to use a single rotary switch to select the cylinder to read on both gauges. So switch position #1 would give me CHT and EGT on cylinder #1, position #2 would give me cylinder #2, and so on.
What sort of switch do I need? Asked another way, what is the description that I should look for in "switch catalogs"? I'm vaguely thinking I need a "dual pole" switch. Any good sources to recommend? Do the wires from the CHT and EGT gauges have to be installed and routed in some particular way? I hear them called some special "thermocouple" wire. Can I simply bundle them together in the engine compartment. find some way to route them through the rear bulkhead and on to the switch, cut to length and solder to the switch and then use regular electrical wire to connect switch to gauge? I guess the problem really is, I'm unclear how the CHT and EGT gauges get readings from their respective probes.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Sorry, I should have done some more research before posting. I went to egauges.com and read the installation instructions for the VDO CHT and EGT gauges. The CHT gauge requires two leads from the probe, the EGT gauge also requires two leads from the probe, so the switch in my idea would have to be switching four circuits at once. I'm not sure such a thing is easily found at all.
Omega is your friend . . .
http://www.omega.com/techref/ http://www.omega.com/guides/thermocouples.html http://www.omega.com/toc_asp/subsectionSC.asp?subsection=H10&book=Temperature http://www.omega.com/ppt/pptsc.asp?ref=DP1000&Nav=temm06 For what you want to do the scientific instrumentation route would be a bit more practical than anything an auto instrument manufacturer can provide. Last edited by 350HP930; 04-01-2005 at 04:18 PM.. |
Senior Member
Also:
http://www.aircraftspruce.com/catalog/inpages/alcor_egtchtsys.php http://www.aircraftspruce.com/catalog/inpages/westcombos.php
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Does anyone have photos of the square aircraft-style gauges installed in a 911? I wonder if it looks okay.
Alternatively, I guess I could buy the switch and probes from aircraftspruce and try to use them with a VDO gauge.
old pic.. It's not a necessary line of sight instrument for my act. I know when driving is getting warm, then I'll pay big attention.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Re: Source and Installation For CHT/EGT W/ Six-Position Switch
