Where did my fifth gear go?
Here's the deal: '83 SC, 915 gearbox, everything rebuilt or replaced (gearbox innards, shifter coupling, factory short-shift kit) 9,000 miles ago. Drove a DE at Lime Rock yesterday, and ever since haven't been able to get the gearbox into fifth. It to go left against the spring, to the stop, and up into fifth but it actually is fourth. Just went out and adjusted the shifter coupling per factory parameters, still doesn't work. Should I be looking at the shifter itself? Something inside the gearbox?
Nothing unusual about the DE. Lime Rock is driven entirely in third with fourth for the straight, one upshift and one downshift per lap, they were all routine during a total of about 1.5 hours of track time, all those shift worked fine.
Any advice?
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-01-2005, 10:46 AM
Driving member
jester911's Avatar
Still figures to be the shift coupler.
Mark the shift rod in relation to the coupler in its current position for reference.
Then make minor adjustments to find the right spot.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 04-01-2005, 11:06 AM
al lkosmal's Avatar
This is most likely a coupling adjutment problem. I start with the recommended setup, but always have to trial and error re-adjust to get it right. The trick is to set it per recommendations, mark the position.
Try it out. If works on all gears except 5th, notice the direction the coupler rotates prior to stopping. I.E. it needs to be able to rotate more, in this direction, to engage 5th gear. Using the mark to keep track, re-adjust the coupler to allow slightly more rotation, in the direction of 5th gear. Do this in small increments until you can engage 5th gear, then verify that you can engage all other gears. Repeat until thoroughly pissed off. Stop, have a beer! Try again.
I hope that this is clear. Hopefully it's just an adjustment problem.
Good luck.
Al
RGruppe #669
http://www.x-faktory.com/
Old 04-01-2005, 11:08 AM
Super Jenius
Overpaid Slacker's Avatar
Send a message via AIM to Overpaid Slacker
Where did my 5th gear go?
I ask that all the time in my 79 930... weird.
JP
I believe it's the coupler as well ... like many other things, sometimes they do just get themselves out of alignment. If it was internal to the gearbox, the lever would probably go into where 5th should be and you'd hear the problem immediately.
2003 SuperCharged Frontier ../.. 1979 930 ../.. 1989 BMW 325iX ../.. 1988 BMW M5 ../.. 1973 BMW 2002 ../..1969 Alfa Boattail Spyder ../.. 1961 Morris Mini Cooper ../..2002 Aprilia RSV Mille ../.. 1985 Moto Guzzi LMIII cafe ../.. 2005 Kawasaki Brute Force 750
Old 04-01-2005, 11:58 AM
Driving member
jester911's Avatar
If I had a persistant problem with the coupler I think I would try the wevo. It supposed to take care of the problem.
Jerry
Old 04-01-2005, 12:02 PM
Certified Pre-Owned
BGCarrera32's Avatar
If reverse works I would think 5th would be o.k...
'84 Carrera Coupe
Old 04-01-2005, 12:17 PM
al lkosmal's Avatar
No,
I have had mine adjusted with reverse working easily, but still no 5th.
Al
RGruppe #669
Old 04-01-2005, 01:01 PM
Found the problem. I finally noticed that the set screw/locater pin that fastens the coupler to the transmission rod had come a tiny bit loose. It's amazing how little "lost motion" at that point can keep the shifter from selecting a gear despite the coarseness and amount of displacement at the shift lever. Good place for Loctite, since it came loose in only 9,000 miles of use... Thanks to all, you guys were exactly right, the problem was in the coupler, though I was looking at iuts front end rather than rear end.
Stephan
Stephan Wilkinson
Old 04-01-2005, 01:12 PM
Wavey's Avatar
You should write a book about that car, Stephan. I'll bet a lot of guys would find it interesting.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 04-01-2005, 02:59 PM
I could call it Gold-Plated Pathetic.
Stephan
Stephan Wilkinson
Old 04-01-2005, 03:12 PM
Wavey's Avatar
Best laugh I've had in a month! I swear to God - I just wet my pants. This stuff is definitely funnier without the smiley faces.
Old 04-01-2005, 03:21 PM
I've never understood the need for whatever they call them, iconographs or something. "Gosh, Mr. Hemingway, I really don't understand what you mean. You need to learn to type parentheses and semicolons."
(Uh-oh, I think I may have just started something...)
Stephan
Stephan Wilkinson
Old 04-01-2005, 03:46 PM
Driving member
jester911's Avatar
Steven that is classic. Good for a April 1 laugh.
Glad your coupler worked out.
Jerry
Old 04-01-2005, 03:48 PM
