86 911's Avatar
Send a message via AIM to 86 911
Perma-Tune CDI power gain
I have a Perma-Tune CDI box installed on my '79 3.0 engine. How much more power (if any) is gained with the Perma-Tune rather than an OEM Bosch unit?
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 03-30-2005, 03:52 PM
nada
206 637 4071
Old 03-30-2005, 03:54 PM
86 911's Avatar
Thanks JWW. What would be the difference between the Bosch and Permatune CDI box? Just the brand name?
Matt
'71 VW Bus
Old 03-30-2005, 03:57 PM
Senior Member
Superman's Avatar
Careful what you ask for. If you're asking Warren about the differences, you'll get more schematic diagrams than you've ever seen in your scariest nighmares. If you're asking for opinions, everyone's got a strong one here. For my money? I'd say Bosch is the most durable, also the most expensive to buy. After that, I was advised by a highly respected poster and longtime 911 guy that Permatune was better than MSD. Others believe differently. Also for my money, either there is a spark and the gasoline burns, or there is a problem. Barring a problem, they all work the same.
Mocha 1978 911SC. "Coco"
Old 03-30-2005, 04:21 PM
Re: Perma-Tune CDI power gain
you need the carbs.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-30-2005, 04:45 PM
pwd72s's Avatar
Re: Re: Perma-Tune CDI power gain
Originally posted by RoninLB
you need the carbs.
(edit) Ron, would you like to tell us again about your "out of this world" permatune experience???
Old 03-30-2005, 05:30 PM
No, the Bosch unit works extremely well.
In fact the two boxes are different internally. JW doesn't need me to confirm what he said about performance gains, but..."nada" is right on.
My car is on the Atkins diet and can't have carbs.
'80 SC
Old 03-30-2005, 06:36 PM
Re: Re: Re: Perma-Tune CDI power gain
short story is that it's a real Area 51 story..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-30-2005, 06:55 PM
86 911's Avatar
Thanks for the info guys. I have a spare Perma-Tune that I bought off of a fellow Pelican a few months ago. Thankfully I never had to use it after all, and it will act as a spare.
Matt
'71 VW Bus
Old 03-30-2005, 08:09 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
You wont gain any power at all... the only upside I've seen is that it's cheaper than the stock unit, and I havent seen as much wear and arcing on the cap/rotor.
Quite honestly, I would just go to the MSD 6AL. I had THREE Perma-tune units fail in the span of 6 months (all three times, units were replaced by Permatune with rebuilt ones maybe a guy just wasnt paying attention on the line?) before I installed the MSD and havent had a problem since.. If you do go this route you'll need to use either a Bosch blue coil or the MSD Blaster coil as the stock one wont work. You'll also want to gap the plugs slightly larger than stock..
Old 03-30-2005, 10:57 PM
3 perma-tunes in 6 months suggests a problem with your car, not the units.
206 637 4071
Old 03-31-2005, 08:28 AM
Logic would suggest so... Since the MSD was installed, havent had any problems....
Old 04-02-2005, 10:19 AM
