Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Help! Need sizing of threaded CIS fitting on later gas tank
HI...I need to get an adapter for my new fuel tank, which I think came out of a 79. It's got a threaded connection where the hi pressure CIS stuff connected to it. I'm at the office at the moment, and don't have access to a service manual. Does anyone know the size of that threaded connector on the gas tank?
Thanks!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-04-2005, 01:01 PM
I would rather be driving
jpnovak's Avatar
78 tank to a 71 car. this adapted the tank to the tunnel. I still have a rear mounted fuel pump.
Fuel tank return fittings
Old 04-04-2005, 01:08 PM
Rennch on YouTube
rennch's Avatar
Ok...so I'm clear...
You ran your SUPPLY side off the drivers side, bent fitting, and the RETURN side to the 14mm X 1.5 (Thanks for the size...) side?
Michael O'Neal -
Old 04-04-2005, 01:14 PM
jpnovak's Avatar
HMM I don't remember which goes where. The adapter allowed me to hook both up to the tunnel. Our of the tunnel I have two lines. One is supply to my fuel pump and the other is return. I think the larger diameter is the return.
Old 04-04-2005, 01:52 PM
Rennch on YouTube
rennch's Avatar
I think I'm set, using those settings you had from the previous thread. Thanks for the help.
Michael O'Neal -
Old 04-04-2005, 01:54 PM
scottb's Avatar
emptyo: you have mail.
1984 Targa
Old 04-04-2005, 04:14 PM
