Hay 911mot, where do you work? I might have had my care in with you, but do not know??
MODIFY it. Make it yours, make it YOUR dream car.
As said before an SC is a $10k car no matter what... stock or with any mods... GO WILD!!!!!! |
Rickmansworth nr Watford.
I told the driver how to check oil and stuff and also to check out this website.. |
Hmmmm, I am in Rickmansworth nr Watford (part-time), but it was not me you spoke to :o(
Re: Keep it original or modify it?
You can make it look like mine. http://forums.pelicanparts.com/uploa...1112815810.jpg |
I could... But then it is not an sc :o) BTW - Nice Car!!
Its a shame to hack a nice original car..ask the 356 guys. I've got the same vintage and I am the second owner for the last 20 years. I try very hard to keep it the way it was, at least on the surface. The 3.0 is now a 3.2 SS..it has footwell blowers where there weren't ones. But it still looks like a 78. The people on this board are evil, yep,evil doers[ can't remember what jerk coined that term]. They will lead you down the path of modification. You think your tough and you can handle it..just one hit for the rush..maybe a ruf valance. But you will soon be pimping your wife for the cash to feed your habit. Take the high road, keep it stock. Your wife will thank you.
My opinion is: if you intend to keep the car until you die or its totalled, modify it to your heart's content. If you think you'll sell it on, if there's another Porsche you hope to switch to somewhere down the line, and - most important - if your mods are cosmetic rather than performance related, leave the car alone. Flares on your 911T with 3.6 for wider tires so you can do better on the track = good. Flares on your 911T with 2.2 because you wish you had a turbo = not good.
Emanuel |
I totally agree with this statement. I came here with a nice totally stock 88 Carrera just 1 year ago... In a couple of weeks my car will look like a 934, will have a 3.6 engine and 9.5' and 11' wheels... If you are weak the dark side will seduce you... and then there is no turning back. |
In the infamous words of MikeZ - A stock car sucks. Make it yours - there are lots of improvements for 70's and 80's technology.
And if everyone were to become stock freaks, Pelican Parts would be out of business. |
I am thinking that for now I will retain the original sc look, and upgrade the mechanics. After all I got the sc, as I really like the way it looks.
Paal,
It's your car. Plenty of SC's around so why not make it a bit personal? Removing the bumpers is easy and should you later in life regret you just put the car back to standard. Now that's was easy. I did the same. Bought SC, then replaced bumpers, did the brakes, then the suspension, oh and the seats. Then we did the wheels and the motor, then gearbox and so it went. Today the car is MINE (actually it's for sale) and it will never be an SC again. But it is really the best 911 in the world. SO - just change the bumpers. Regards Tom |
Thank you Tom, do you have any pic's of your SC??
Tom MY 911 will be the best 911 in the world :D :D :D
http://forums.pelicanparts.com/uploa...1112892033.jpg
Trust me - this car was 100% original in '99. Today only the windscreen and the colour (stickers are gone) is standard! Stretching the theme maybe - but awsome and fun. Trust me, this car will eat most. Regards Tom |
I recently sold my boxster to try a 911...Since I couldn't afford the year/options I wanted, I got the best I could afford and am slowly (as the wallet & wife will allow) adding modifications to get it where I want....
I have an 84 3.2 targa that is getting: C2 body updates (half done) 993 door panels (gong in this weekend) boxster seats (already in, love them) S. Wong chip (already in, wow!) I am going to convert it to a cab in a few weeks....(as soon as I learn how to weld) All ideas I have either gotten or learned how to do from the esteemed knowledge base found on this board....(thanks) The way I figure it, as long as the work is all done professionally and top notch, it shouldn't affect the value much.. Chris |
Hi Tom, where in the world are you (that does not look like a US reg to me??) I have tried to locate the same style front bumper and valance, and can only find suppliers in the US - can you point me to a supplier in Europe?
You gonna have to do more than that to beat this one. http://forums.pelicanparts.com/uploa...1112892651.jpg http://forums.pelicanparts.com/uploa...1112892668.jpg http://forums.pelicanparts.com/uploa...1112892694.jpg http://forums.pelicanparts.com/uploa...1112892720.jpg http://forums.pelicanparts.com/uploa...1112892742.jpg http://forums.pelicanparts.com/uploa...1112892766.jpg 83' Porsche 930 turbo euro 450rwhp@1bar (dyno tested and tuned) Air cooled engine (flat 6) Motor rebuild by Poudre Sports Car, 86k miles on the chassis and 23k on the motor 3.3L 7:1 compression, 91-92' C2 turbo Mahle fully finned cylinders Cylinders thermal coated Piston tops ceramic coated Skirts dry lubed OEM SC cams New rocker arms Rod bolts, raceware hardware Head studs, raceware hardware New timing chains and latest chain tensioner upgrade to 84' design Billet sump plate with new drain plug Smart Racing solid motor mounts with modified trans. mount New alternator/belt and brushed shroud and fan blade New exhaust valves Ignition New Beru spark plug wires New Beru S9 spark plugs New rotor and cap Distributor re curved by Jerry Woods 4spd manual transmission/clutch/shifter Rebuilt transmission also by Poudre Sports Car, 12k miles ago 8:39 Ring and Pinion (David Brown) done by Carquip 40% LSD with SWEPCO 210 transmission fluid WEVO 930 shifter with race knob and leather shift boot Smart Racing shift coupler and bushings Hi torque starter KEP Stage II pressure plate 993 disc and new stock flywheel New clutch cable Rebuilt drive axles with new boots CIS Fuel System Fuel injectors balanced by C&C Fuel Injection Euro fuel head (more fuel than the US one) rebuilt and for 17% more fuel Both fuel pumps replaced WUR modified with use of an MSD rpm activated switch (with rpm modules) for on boost fuel enrichment Surge filter for the fuel cutoff switch Air intake/Turbocharger Power flow intake Ram/Cold air intake to turbo done by Redline Motorsports Kokeln racing IC with billet CBV Throttle body plate knife edged Manifold Extrude Honed Injector blocks tapered to match manifold ports Modified Kokeln turbo, 60-1 compressor wheel with a .71 A/R, 360 deg. thrust washer and Stage V turbine TIAL 46mm wastegate with a .6bar spring Water mist system that sprays IC from the headlight washer spray switch inside Modified AAR for better idle when cold Exhaust GHL headers with heat and aftermarket sump (new silicone heater hose) Dual look 3" Fabspeed muffler with wastegate pipe and 4.5" oval tips Oil cooling 14 quarts of Mobil 1 oil Aftermarket oil cooler between the oil tank and engine oil cooler Cool collar for oil filter Elephant Racing finned supply line to front mounted oil cooler Kokeln Racing oil cooler, had to be repaired Spal fan for Kokeln oil cooler, for light switch inside used to turn fan on/off Ducting through port where the fog light was Horns relocated to under drivers side fender Water mist system that sprays oil cooler from the headlight washer spray switch 2nd Gen. Big Brakes New front and rear rotors Front and rear PAGID sport blue pads Stainless steel brake lines OG Racing front cool brake kit with Smart Racing deflection shields ATE Super blue brake fluid Removed front and rear brake dust shields for more cooling Suspension Kokeln racing front strut brace Front and rear Sander Eng. Torsion bars 22/31mm Rear sport shocks 86-89' front and rear sway bars with new buushings Tarrett Eng. Rear drop links Suspension alignment and corner balanced with load checker, 38/62% Wheels/tires Sumitomo HTR Z fronts 225/45/17, rears 255/40/17 Mille Miglia 17" Cups, fronts 7.5", rears 9" with aluminum Porsche crest center caps Interior AJ USA sport steering wheel and hub with manual rack and pinion steering Porsche aluminum door handles RECARO Speed line seats WEVO shifter and boot already mentioned Greddy Profec-B boost controller Westach vac./boost and EGT gauge Andial IC temp gauge UEGO 1000 A/F wide band CD player with front and rear speakers Matching Porsche crest on glove box door. Turbo door sills Up front an Odessey PC-680 battery with a Hela cut off switch Upgraded headlight bulbs to 80/100 watts Power windows Power mirrors Power sunroof Leather interior Alarm system Wide body Original paint, Burgandy color with rock guards Whale tail Front 86-89' lower valance with fog lights removed Bra (black) and car cover (grey) Chip near drivers door handle on quarter panel Special tools 12 point/12mm flywheel socket Engine/transmission jack adaptor Valve adjustment tool Fuel tank plug drain tool (custom made) CIS fuel pressure tester Jack pad Tool kit with jack Clutch disc alignment tool What the car needs or what doesn't work The glove box light won't light when the headlights are on and you open the glove box (no plans on fixing) Headlight washer spray and windshield wiper spray won't work due to the water mist system now in place As well the washer reservior has been removed to clear the front drivers tire from rubbing There is no spare tire, the water bag for the water mist system is there Fog lights don't work because they have been removed and the switch used for the oil cooler fan (already mentioned) Ignition switch needs replaced (going bad) Valve adjust, oil and filter change Note: Emissions test needs done if sold (there are no emissions on the car but I will get it passed) |
ONly way i would keep it untouched if there were no damages ( ie crashed car ) , documented history from day 1, and i would be 2nd owner.
Other wise i would/will change it to suit me and my tastes. go for the mods! |
| All times are GMT -8. The time now is 05:10 PM. |
