Does your coil have a boot?
I recently installed some new Clewett wires. I ran the engine in the dark and noticed a lot of arcing from the center coil lead to the two primary leads. When I checked Pelican I noticed that there is a coil boot that my car does not (but will) have.
http://www.pelicanparts.com/catalog/images/ignition/9-1-12.jpg Does anyone have any useful comments or observations concerning this boot? |
I just replaced mine with Magnecores. The coil boot is just a cover for the coil.
If you are arcing as described, my opinion is you have another problem besides a missing boot. A new boot may just hide the problem, Those with more expertise may help you further. |
something ain't kosher.
cracked coil, oil/grease up there, weak coil wire boot, etc
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Virginia Rocks!
Re: Does your coil have a boot?
Put a boot on there by all means. I put on the MSD system. I didn't put on the boot I ordered because the blaster coil was a little too big for the hole and I didn't have my Dremel. Ran it for a couple of weeks and then got around to replacing and regapping the plugs. I think I make have not pushed the coil to cap wire into the coil all the way, but it blew a hole in the side of the coil and eventually arced down to the terminals. Ruined the coil to cap wire as well. I ordered new wires and a new coil the next day. Dremeled out the boot to accomodate the coil. ![]()
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Thread Tools | |
Rate This Thread | |
