Classic's Avatar
Question What struts have i got
I know it's been asked before, but i'm confused i think a might have the self leveling stuts. But then i don't have the rubber dust cover that i can see in the parts dig.
So maybe they have been changed?
no tie rods but, which with what i've read is the main indicator of self leveling struts.
And just to confuse the matter there painted green..... when i removed the over spray?
Classic 1969 911T
Old 04-07-2005, 04:59 PM
Somewhere in the Midwest
MotoSook's Avatar
Looks like Boge. There should be BOGE stamped on the strut.
Old 04-07-2005, 05:22 PM
Classic's Avatar
Thanks i'll have a look for a stamp
Classic 1969 911T
Old 04-07-2005, 05:37 PM
Either Boge or Bilstien. Look for a roll pin at the bottom of the assembly above where the ball joint bolts in. If there is one, its a Bilstien. If not, Boge.
Chris M
1985 911 Carrera w/ 3.6
Old 04-07-2005, 05:44 PM
My guess would be Boge struts with Bilstein HD inserts. The bottom is black which is usually Boge, and when you buy Bilstein inserts they come with new dust covers in Bilstein colors.
Old 04-07-2005, 07:09 PM
More Likeable IRL
juanbenae's Avatar
exactly what he said.
Old 04-07-2005, 08:13 PM
Licensed User
Shuie's Avatar
black = boge
green = bilstein
red = koni
yellow = koni or bilstein
Those are alloy S calipers, right?
S brake calipers means you have 3.5" ears on the struts. If those are Boges, they would be from a later car like an SC. The Boges that were use on the earlier cars had the 3" ears, brakes were steel M calipers. 3.5" earred struts on a '69S or an S optioned T should be Koni Reds
Saying all that to say that I bet they are Boges from a later car
Old 04-07-2005, 08:55 PM
Zeke's Avatar
When looking for the stamped writing, you will usually find it on the inboard side down low just above the spindle collar. It's very faint. Scrub the strut tube with a ScotchBrite pad or some steel wool.
Old 04-07-2005, 09:01 PM
Classic's Avatar
wow thanks guys
I'll check for the roll pin and the stamping.
I'm renewing the front during a full resoration of the car and wanted to make sure i didn't order the wrong parts.
Classic 1969 911T
Old 04-07-2005, 10:48 PM
