billyboy's Avatar
glovebox door
Can someone give me a quick tutorial on how to remove a glovebox door/lid on on early car? I don't want to ruin anything by prying etc.Thanks.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 04-09-2005, 11:27 AM
drag racing the short bus
dd74's Avatar
Lots of little Phillips screws hold the door in place IIRC. I do know NO PRYING is needed. Just some vigorous pushing. You won't hurt it though; the piece is quite strong (and heavy, considering).
The Terror of Tiny Town
Old 04-09-2005, 11:44 AM
poorsha's Avatar
You have to take off the knee pad which will allow you access to remove the inner pocket which will allow access to the screws to remove door (if my memory is corect after the abuse it went thru during the early 70's. And mid and late 70's and early 80's. I think).
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 04-09-2005, 01:06 PM
yeah, you have to take off the knee board. its held on by two nuts, 8mm wrench i think. The center one is about 4" from the ash tray end. the other is pretty close to the door end. The center one is a pain to get at. you pretty much have to lie down, and work by feel. Once you get the knee board off, you can easily get at the philips screws that hold on the door.
hope that helps,
jason
motors: 73.5 911 T targa - RIP, 2005 Subaru Legacy 2.5i
pedals: Ellsworth Truth, Neuvation road bike
Paddles: Dagger Ego
Wind: Liquid Force kites/Ocean Rodeo Mako board
Old 04-09-2005, 07:07 PM
randywebb's Avatar
If you take it off, how abotu tossing it on a postal scale and posting the wt.? Your data will then become part of the Wt-Borg...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-09-2005, 07:17 PM
bjmullan's Avatar
My glovebox has a broken key in it so is this method suitable for getting my glovebox open as well? If not what is the best way of getting it open so that I can the lock replaced or repaired?
Brendan
1969 911T
Old 11-24-2005, 03:03 PM
bjmullan's Avatar
I should have kept searching. as this place seemed to have the answer to most problems. Got the answer (I think) at Glove box is stuck closed...what to do?
Brendan
1969 911T
Old 11-24-2005, 03:09 PM
cycling has-been
bkreigsr's Avatar
I drilled a 3/4" hole in the bottom of the box & used a long screwdriver to release the catch at the top of the frame. replacement mouse-hair box was $15.
btw the wt of the box alone is less than 4oz.
Bill K
Old 11-25-2005, 05:15 AM
