twobone's Avatar
AC delete "lite"
I've got to believe that my AC has long since drained. I don't think its worked in years.
81'SC
If I want a short 2 hour job underdeck lid clean up, can I just remove the condensor and the finned radiator under my decklid along with the visible hoses?
Any other words of advice?
Old 04-09-2005, 05:58 PM
Send a message via AIM to fintstone
The condensor is the finned radiator on your rear deck. You must mean the compressor....You should be able to easily remove both in a couple hours if you have the proper tools
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-09-2005, 06:58 PM
MovOvr1's Avatar
I had the same thing done with mine. I didn't cut any of the hoses I just tied them together and they sit at the back of engine compartment out of the way.
Brian
BLK 79-930
Old 04-10-2005, 09:35 AM
