Kirk911SC's Avatar
Cold control pressure was 65 psi (with the engine stone cold) - much higher than spec. System pressure 75 psi (normal), rest pressure 22 psi after 10 minutes (normal).
Car was bucking, backfiring badly, wouldn't rev, bad exhaust smell, hard to start, rough idle.
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 04-15-2005, 08:11 AM
are you checking ccp with the wireing harness still conected?? if so you will see those numbers. I would guess your co is off wcp should be in the 55 range what is yours?? do you have ben watts cis book??
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-18-2005, 10:33 AM
Kirk911SC's Avatar
All the pressures are in the normal range with the new WUR. I still haven't got the CO set right yet, but the car is driveable, just down on power. I'll get it right eventually........still think I'm too rich.
Kirk
Old 04-18-2005, 10:46 AM
Designer King
Paulporsche's Avatar
If you search you can find the push/pull method of setting your CO, or you can adjust to the point just before the idle speed fluctuates, or (of course) you can have it set w/ a gas analyzer. JW likes 3.5%.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-18-2005, 01:13 PM
Rick Lee's Avatar
But wouldn't a bad WUR only affect the first few minutes of drivability? I know my WUR is bad, but I just have to let the car sit for 1-2 min. after cold startup and then it's fine. I had had the mixture way rich, but the wrench brought it down from 5.25% to 2.25% and everything is MUCH better now. I guess I'll start planning on a WUR rebuild or tweak, but I can live with a 1-2 min. warm-up before taking off.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-18-2005, 01:50 PM
Kirk911SC's Avatar
Warm-up regulator affects control pressure all the time.
I think mine was causing too high a pressure all the time, and causing a very lean run condition.
I tested the new WUR after install and it spec'd out perfectly.
Old 04-18-2005, 03:26 PM
