Licensed User
Shuie's Avatar
3.2 Carrera engine swap oil line backdate
Im starting the plan for a 3.2 carrera swap into my car. No more changing my mind about my engine. Im not kidding, its actually in my garage.
The engine has the stock 3.2 hard oil line coming from the pump to the tank. Can I have a hose fabricated to go from the end of the stock 3.2 hard line to my '72 tank, or do I need to backdate the oil lines? Whats the 'right' way to do this?
TIA
Old 04-17-2005, 09:32 PM
Bill Verburg's Avatar
The stock '72 lines should work fine
Bill Verburg
Old 04-18-2005, 06:36 AM
Nevermind, I just saw in your other post that you are using the 3.2 exhaust.
Yes, you will need to have something made unless Chuck has something on the shelf
Bill Verburg
Old 04-18-2005, 06:38 AM
Licensed User
Shuie's Avatar
So is there any harm in jumpering the oil line over to the stock tank if i keep the 3.2 exhaust?
TIA
Old 04-18-2005, 07:21 PM
Licensed User
Shuie's Avatar
bump
Old 04-23-2005, 03:04 AM
addictionMS's Avatar
I would consder updating my oil tank, a 3.2 tank fits in the space if you cut away some of the body where the old tank was, that is how I did it, then everything works.
Does a 72 have an oil cooler already, if not ask and I will point you to how I overcame that issue on my 1970
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 04-23-2005, 07:52 AM
Licensed User
Shuie's Avatar
nope, no oil cooler. Ive seriously thought about losing the '72 oil system. Coolness factor aside, its going to be a PITA with this engine swap. I know that eventually Im not going to be able to find parts for it.
Old 04-23-2005, 08:16 AM
check out these pictures
http://addictionmotorsports.com/vodiOilLines.htm
there is no indent in the rear inner fender on the earlier cars so I ended up looping the oil lines up in the rear fender area, the pics kind of show that.
I can take more if you need a better view
Jim
Jim Hamilton
Old 04-23-2005, 08:43 AM
Todd Simpson's Avatar
Jim-Those are helpful pictures for me, related to a thread I posted a week or so ago.
275's on the rear with RS flares
Thanks!
Old 04-23-2005, 08:57 AM
randywebb's Avatar
You've thought about using an SSI exhaust and the hoop type oil line?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-23-2005, 10:46 AM
