GOT TURBO..
MobileWrks's Avatar
cis question,never ran into this problem..
The fuel dist head is off a different cat,i believe the engine is a 79, to a 75 chasis. WAR is new, head was bought from ebay. when the engine is under cranking and running, here is what goes on..........
Sensor plate splutter erratic ( sounds like a small toug boat )
only idles if timing is far advanced ( still spluttering,electronic points )
Some plugs,dark and dry,a few dark and wet,one wet no carbon,( Fuel head is adjustable,im thinking someone may have tampered with it...)
With old WAR, car was at 1 bar hot and idled, but ran like junk if drivin -
Fuel pump pressures good, WAR new,head bought used,or do i need to have the head sent out to match enginedoes anyone know who does FD tuning with it off the car???????
Old 04-18-2005, 08:53 PM
Send a message via AIM to fintstone
apparently these guys do (no affiliation)
http://www.fuelinjectioncorp.com/products/distributors.php
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-18-2005, 11:06 PM
GOT TURBO..
MobileWrks's Avatar
THANKS>>.i found the problem..... head is one, also the entire system is miss matched......
Old 04-19-2005, 09:41 AM
