GOT TURBO..
cis question,never ran into this problem..
The fuel dist head is off a different cat,i believe the engine is a 79, to a 75 chasis. WAR is new, head was bought from ebay. when the engine is under cranking and running, here is what goes on..........
Sensor plate splutter erratic ( sounds like a small toug boat ) only idles if timing is far advanced ( still spluttering,electronic points ) Some plugs,dark and dry,a few dark and wet,one wet no carbon,( Fuel head is adjustable,im thinking someone may have tampered with it...) With old WAR, car was at 1 bar hot and idled, but ran like junk if drivin - Fuel pump pressures good, WAR new,head bought used,or do i need to have the head sent out to match enginedoes anyone know who does FD tuning with it off the car??????? |
apparently these guys do (no affiliation)
http://www.fuelinjectioncorp.com/products/distributors.php
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
GOT TURBO..
THANKS>>.i found the problem..... head is one, also the entire system is miss matched......
Thread Tools | |
Rate This Thread | |
