hagfish2's Avatar
How do I know if I have LSD on my G50?
How do I determine if my 88 Carrera has LSD?
2005 Seal Gray 997
Old 04-18-2005, 09:15 PM
ZAMIRZ's Avatar
jack the rear of the car up, put it in gear and turn one of the rear wheels with your hand. If the other rear wheel moves in the opposite direction to the one you're moving with your hand you DO NOT have LSD.
Amir
'83 911SC
Old 04-18-2005, 09:17 PM
Slackerous Maximus
HardDrive's Avatar
Its seeing pretty colors and wants to listen to Pink Floyd?
Sorry....couldn't resist...I'll get my hat......
2014 Cayman S, PDK
Jack the car so that both rear wheels are off the ground.
Put it in neutral.
Turn one wheel with your hands.
If the other wheel turns in the same direction, you have LSD.
If it turns in the oposite direction, you don't.
88 BMW 325
86 911 Turbo
Old 04-18-2005, 09:19 PM
Didn't type fast enough
88 BMW 325
86 911 Turbo
Old 04-18-2005, 09:20 PM
Somewhere in the Midwest
MotoSook's Avatar
Go out on a lonely stretch of road and see if you can lay two rubber strips I test mine now and then...
Old 04-18-2005, 09:38 PM
I'd probably skip that test. Spawned from hell wheel hop will likely follow.
Old 04-18-2005, 09:44 PM
