-   -   Replace that clutch fork!? (G-50) (http://forums.pelicanparts.com/porsche-911-technical-forum/217100-replace-clutch-fork-g-50-a.html)
MotoSook 04-18-2005 09:43 PM
I know what the answer is, but never thought to find this! There is a hole in the casting when the metal has worn...past the normal contact surface.
Anyone find this before? Common?
http://forums.pelicanparts.com/uploa...1113885717.jpg
MotoSook 04-18-2005 09:56 PM
Rubber center clutched disk...
From the same car...
Rubber centered clutch disk to be replace by the Sach spring center disk.
http://forums.pelicanparts.com/uploa...1113886440.jpg
90K+ miles and everything is dry! Will replace the rear seal anyhow since it's accessible. Don't want to have to go in there later. Flywheel is colored, but smooth...will lightly resurface and reuse..bad idea? Maybe, but I'll check it out first.
http://forums.pelicanparts.com/uploa...1113886535.jpg
Yucky crud (it's thicker in person) on an otherwise very clean car....I'm sure the heat transfer was piss poor. The case will get cleaned to bare aluminum!
http://forums.pelicanparts.com/uploa...1113886612.jpg
sushinav 04-18-2005 10:19 PM
Mines got 135k and no hole in the fork. Although the shaft bearing and throwout guide tube update was done at about 90, but I'm not sure this would have an effect. Also I've read that the G50 rubber center clutches were a solid item and didn't have the issues of the earlier rubber center cars. Are you thinking of spring centered for cost reasons or other?
Cheers,
MotoSook 04-18-2005 10:25 PM
The cross shaft was updated on this tranny. Don't know if it has anything to do with the wear, but the fork casting may have had an inclusion or void at the contact point which started the whole thing. The clutch was behaving funny when things got hot. So we're taking the safe route and replacing it.
ZOA NOM 04-19-2005 08:49 AM
Replace the Speed, TDC and Reference sensors while you're there.
fuelie600 04-19-2005 11:19 AM
Souk,
When I did my clutch/g50 update last year, the flywheel was smooth but discolored - like yours. Now that it's back together I get a slight clutch stutter, but only in reverse. I don't know if its the clutch or not. I don't feel it throught the pedal. I'm thinking it's the engine mounts getting soft, but it could be the clutch.
I'm going to replace the mounts after I get throught with a couple of other projects.
I would really go over well before you put it back in. If you reuse it, let me know if you get any stutter.
Rick Lee 04-19-2005 12:43 PM
When I did this job, I was told by several that G50 flywheels can't be resurfaced. I got a new one locally for around $210. To avoid digging into your new clutch fork, use a dab of moly grease on the slave push rod when you reinstall. Definitely do the cross shaft update.
MotoSook 04-19-2005 12:46 PM
The tech info available says it's not re-surfacable. I'll check for thickness.
arerrac 04-19-2005 01:36 PM
I'm planning on doing my clutch next month. My wrench said to look at the flywheel for glazing. If there is glazing, to hit it with a oribital sander with a med type grit to clean up the surface. Said it has worke on all the G50's he done that Were Not warped.
What to you guys think??
-Wade
KTL 04-25-2005 05:38 AM
The reason the tech. info. says the flywheel is not resurfaceable is because of the rubber-centered clutch disc. If you were to take too much off the flywheel surface, the clearance between the pressure plate assy. and the clutch disc hub could be close enough that there would be contact. When installing a spring-centered disc, this clearance problem becomes a non-issue.
Nonetheless, i'd only resurface the 'wheel an amount to freshen the surface. If warped, it'd probably be best to replace it.
Souk,
I'm certain you've got the updated shaft assembly.
Check out this topic
G50 Clutch Cross Shaft Information
JeremyD 04-25-2005 05:47 AM
My wrench recommends just scuffing up the surface of the flywheel with a hand sander. Just enough to take the color off the flywheel.
MotoSook 04-25-2005 07:21 AM
Right on all points Kevin and Jeremy. I just have to clean up the installation a bit, as the update was not performed to "my spec."
PorscheGuy79 04-25-2005 08:03 AM
Nice Souk, you been busyer than I could have imagined.
MotoSook 04-25-2005 08:07 AM
It's tough working two jobs Matt...Sorry if I've been slow.
PorscheGuy79 04-25-2005 08:13 AM
Dont worry about it, right now I know how you feel.
rick-l 04-25-2005 08:26 AM
Since these two sensors consist of a coil of wire and a magnet, i wouldn't thnk they would wear out very fast. More important would be to check the gap if you install a new flywheel or bump it.
MotoSook 04-25-2005 08:29 AM
I think it's the whires and wire insultor that folks are concerned with. If they are pliable, I'd be OK with it.
Beethoven 04-25-2005 09:06 AM
Where do you think the crud on the engine comes from?
MotoSook 04-25-2005 09:10 AM
The engine is fairly clean, but there is oil vapor condensed around one of the oil lines (vapor from oil tank to the intake). It was a loose hose. Don't know why it was loose.
The crud on the tranny is a mixture of road crud and an probably tranny fluid vapor that comes out of the tranny vent. Nothing to be worried about.
KTL 04-25-2005 10:08 AM
Lack of anality. You should be ashamed of yourself...........:D
Steve87-911 04-25-2005 02:40 PM
Hoping I'm not hijacking, but after I got the G50 fork update, when I release the clutch I can sometimes hear what I think is the fork hitting something slightly. A single slight tap sound. I've seen this to be normal on some other cars and I'm just wondering if this is normal on G50s.
JeremyD 04-25-2005 04:30 PM
how did I know you'd have a problem with that?
Beethoven 04-25-2005 04:33 PM
In order to save space, Kevin's motor has to double as a dining table at home.
fuelie600 04-25-2005 04:35 PM
Steve, my G50 with update doesn't make any noise. I did a spring centered clutch instead of the original rubber centered type FWIW.
Carrera3.5L 04-25-2005 08:47 PM
Hey Souk,
My G50 flywheel was resurfaced by Ollie's. No problems whatsover with the 930 spring-centered disc. Also, no noise issues with the factory clutch fork "update".
http://forums.pelicanparts.com/uploa...1114486789.jpg
Good suggestion by the guy who suggested checking out the head temp, speed & reference sensors. Mine all worked fine, but the heat had gotten to the wire insulation and begun to fray so they wouldn't have lasted much longer. Another while you're in there...
Talk about lack of anality, check out the couple of old allen bolts I reused because I forgot to throw them in the box to go off to cad plating. This still chafes me:
http://forums.pelicanparts.com/uploa...1114486946.jpg
You may want to take a good, hard look at the 3-way fuel line on the top of the motor...:) It doesn't get any easier to change than now.
Is this the motor that is going to become the 3.4L turbo?
Ralph
KTL 04-26-2005 06:23 AM
I've bugged Souk a number of times about the timing and reference senders on his own 3.2. On this motor, they look good to us. Sheathing included.
Only thing I recall being a possible sensor issue was the head temp. sensor. Motor still has the one wire instead of the updated two wire unit. Souk's on it.
The motor also already has the updated troublesome fuel line. I think it was replaced a few years ago due to a fuel smell issue.
All in all it's a really well cared for motor. At 96K miles, 17 yrs., it looks and sounds much better than my motor did at 62K, 13 yrs.!!
Steve,
I've noticed this noise you speak of as well. Mine does it when the clutch is released. I'm guessing it's the fingers on the fork contacting the ears on the release bearing?
