cis co for sc??
I set my co yesterday for 3.0-3.5% as everybodies recomendation and I am not sure that I get the throttle reponse and power with say 2.5% the Ben watts book says if no decal to set 1.5% as default what is your experience??
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-18-2005, 10:16 AM
Designer King
Paulporsche's Avatar
Unless you have to meet an emission standard, why not just set it for what feels best to you?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-20-2005, 10:05 AM
I want to make sure that it does not run to lean.. I reset it and it runs better now 2-2.5% works best
Ben
89 944,85.5 944
914-6werkshop.com
Old 04-20-2005, 10:08 AM
Designer King
If the 1.5% default wasn't too lean, then your 2-2.5 won't be. Are your control pressures/WUR ok? Are you experiencing any lean start or run symptoms?
Paul
Old 04-20-2005, 10:15 AM
fred cook's Avatar
Cool CO settings....
I have the CO set at about 2.5% on my '80 SC. It runs well and gives 17-18 mpg in town and 25-27 mpg on the interstate. I also am running with the O2 sensor unplugged. Hope this helps.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-20-2005, 11:18 AM
