-   -   Dansk doesn't seem to fit... (http://forums.pelicanparts.com/porsche-911-technical-forum/217625-dansk-doesnt-seem-fit.html)
smstcoach 04-21-2005 06:56 PM
What am I missing here. I am trying to install a 1 in 2 out dansk on my 86 coupe. The valence is removed. I have tried to line up the intake with my cat bypass pipe but the driver's side muffler pipe bumps up against the lower bumper. Has anyone had this problem???
http://forums.pelicanparts.com/uploa...1114134895.jpg
afterburn 549 04-21-2005 07:06 PM
I cant see enough of it...dose the other part need to be loosened and slid a head??
on-ramp 04-21-2005 07:07 PM
maybe you need a spacer there?
fastpat 04-21-2005 07:14 PM
I agree with afterburn, take four or five more pics from below and looking back the opposite direction and post them.
smstcoach 04-21-2005 07:27 PM
Here are some more pics...http://forums.pelicanparts.com/uploa...1114136803.jpg http://forums.pelicanparts.com/uploa...1114136812.jpg http://forums.pelicanparts.com/uploa...1114136821.jpg http://forums.pelicanparts.com/uploa...1114136832.jpg
Carrera3.5L 04-21-2005 07:38 PM
Well from the pics shown, it looks like the muffler needs to be rotated upward, as the tips are way too low, even with the valance removed.
I had a 1-in 2-out Dansk just like yours previously when my motor was a 3.2L, and it fit fine. Others haven't apparently been so fortunate.
I now have the same basic muffler, except it is now a 2-in and 2-out because I am using headers. This muffler also fits fine.
Ralph
smstcoach 04-21-2005 07:41 PM
Ralph,
What I am noticing is that the lower bumper is wrapped around toward the rear of the car more on the left than the right, creating the clearance problem. The right side sits fine. Is your lower bumper situated this way? The muffler looks like it is turned down because it is just sitting on jackstands and tends to rotate down with the weight of the pipes when I'm not holding it.
Carrera3.5L 04-21-2005 08:04 PM
Originally posted by smstcoach
Ralph,
No, I didn't have to modify the left side at all, but will admit that the muffler did come fairly close to causing an interference problem.
Thanks for clarifying regarding the jackstands/tip orientation, I couldn't figure out how the tips could sit that low!
Here are a couple of pics of mine when the motor was a 3.2L and used the 1-in 2-out muffler:
http://forums.pelicanparts.com/uploa...1114138955.jpg
and a close-up of the left side tip:
http://forums.pelicanparts.com/uploa...1114139005.jpg
Hope that helps a bit!
Ralph
awcayenne 04-21-2005 09:03 PM
here's my dansk.
http://forums.pelicanparts.com/uploa...1114142438.jpg
my passenger side was about 1inch lower than the driver's side. returned and exchanged 3x. all did the same. finally, had to cut, turn and weld to get it to fit. good luck.
aw
smstcoach 04-21-2005 09:44 PM
O.K., finally got the bugger on. I loosened up the nuts connecting the bypass pipe and then tightened everything together. Fired it up and it sounds awesome! Not ricer like, but kinda throaty. It also looks better than I thought without the rear valence. Now if I can just get the OEM straps to fit...
Thanks for all the help tonight. Does every marque have a forum like this??? If not, they're missing out.
-Jeff
p.s. Hey AW, how did you get your bumperettes off? That was part two of this project, but they are glued on there good. I'm afraid to rip at them too hard. Any advice?
fastpat 04-22-2005 08:35 AM
Originally posted by awcayenne
here's my dansk.
aw
I was afraid someone would say that about the Dansk two outlet muffler. Isn't there a Dansk rep that posts on this forum? What does he have to say about this design/assembly error that's being sold? :confused:
fastpat 04-22-2005 09:20 AM
-Jeff
Glad to see you got it on OK, how did you deal with the outlets being at different angles?
Scooter 04-22-2005 09:45 AM
And I was going to post that I thought you had the wrong muffler, then I see that you got it on. Anyway, if this question comes up in the future, keep in mind that the 3.2 muffler is different than an SC muffler, in that the 3.2 has an indention to accommodate a bypass (edit: crossover) pipe, where the SC does not. I found this out the hard way...so read and benefit from my mistake.
I am glad it worked out, the dual out Dansk on a 3.2 sounds great.
Drago 04-22-2005 10:21 AM
Originally posted by Scooter92
And I was going to post that I thought you had the wrong muffler, then I see that you got it on. Anyway, if this question comes up in the future, keep in mind that the 3.2 muffler is different than an SC muffler, in that the 3.2 has an indention to accommodate a bypass pipe, where the SC does not. I found this out the hard way...so read and benefit from my mistake.
I'll second both comments! ('cuz it was I who bought Scott's single in - dual out)
FWIW my passenger side outlet pipe also hangs ~.5 inches lower than the drivers side.
Nine9six 04-22-2005 10:32 AM
I had posted earlier on the installation of a 1 in, 2 out Fabspeed. I recommended exactly what you did for fitment. Good job, BTW!
Always, when installing aftermarket headers, SSI, pre-muffler, sport mufflers, its a good idea to loosen items within the chain and tighten in increments for quality of fitment.
Now turn down the radio, and enjoy the real music.
Cheers.
Slider79SC 04-22-2005 12:35 PM
Jeff,
To get the bumperettes off, you sometimes have to put the nuts back on (not all the way) and hit then with a hammer in order to loosen the bumperettes from the bumper. They do seem like they are glued on but they are not.
fastpat 04-22-2005 02:36 PM
Ralph
Hey Ralph,
Is that the Dansk pre-muffler I see on your car in that photo? This thread has been very informative, by the way.:)
Carrera3.5L 04-22-2005 02:51 PM
Originally posted by fastpat
[B]Hey Ralph,
Is that the Dansk pre-muffler I see on your car in that photo?/B]
Hi Pat,
Yep, that was the Dansk stainless pre-muffler I used to run. Sold to a local Pelicanite.
Ralph
awcayenne 04-22-2005 03:01 PM
hey jeff, hit them with a rubber mallet. also helps to remove the rear valence first. aw
brcorp 04-22-2005 03:47 PM
Where did you get the muffler? What is the P/N? The earlier version did not have the relief for the heater cross over pipe. Don't ask how I know, but I think I've seen this before.
