smstcoach's Avatar
Send a message via AIM to smstcoach Send a message via Yahoo to smstcoach
Dansk doesn't seem to fit...
What am I missing here. I am trying to install a 1 in 2 out dansk on my 86 coupe. The valence is removed. I have tried to line up the intake with my cat bypass pipe but the driver's side muffler pipe bumps up against the lower bumper. Has anyone had this problem???
Old 04-21-2005, 06:56 PM
Air Medal or two
afterburn 549's Avatar
I cant see enough of it...dose the other part need to be loosened and slid a head??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 04-21-2005, 07:06 PM
on-ramp's Avatar
maybe you need a spacer there?
Old 04-21-2005, 07:07 PM
Banned
fastpat's Avatar
I agree with afterburn, take four or five more pics from below and looking back the opposite direction and post them.
Old 04-21-2005, 07:14 PM
smstcoach's Avatar
Here are some more pics...
Old 04-21-2005, 07:27 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Well from the pics shown, it looks like the muffler needs to be rotated upward, as the tips are way too low, even with the valance removed.
I had a 1-in 2-out Dansk just like yours previously when my motor was a 3.2L, and it fit fine. Others haven't apparently been so fortunate.
I now have the same basic muffler, except it is now a 2-in and 2-out because I am using headers. This muffler also fits fine.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 04-21-2005, 07:38 PM
smstcoach's Avatar
Ralph,
What I am noticing is that the lower bumper is wrapped around toward the rear of the car more on the left than the right, creating the clearance problem. The right side sits fine. Is your lower bumper situated this way? The muffler looks like it is turned down because it is just sitting on jackstands and tends to rotate down with the weight of the pipes when I'm not holding it.
Old 04-21-2005, 07:41 PM
Originally posted by smstcoach
Ralph,
No, I didn't have to modify the left side at all, but will admit that the muffler did come fairly close to causing an interference problem.
Thanks for clarifying regarding the jackstands/tip orientation, I couldn't figure out how the tips could sit that low!
Here are a couple of pics of mine when the motor was a 3.2L and used the 1-in 2-out muffler:
and a close-up of the left side tip:
Hope that helps a bit!
Ralph
Old 04-21-2005, 08:04 PM
here's my dansk.
my passenger side was about 1inch lower than the driver's side. returned and exchanged 3x. all did the same. finally, had to cut, turn and weld to get it to fit. good luck.
aw
Old 04-21-2005, 09:03 PM
smstcoach's Avatar
O.K., finally got the bugger on. I loosened up the nuts connecting the bypass pipe and then tightened everything together. Fired it up and it sounds awesome! Not ricer like, but kinda throaty. It also looks better than I thought without the rear valence. Now if I can just get the OEM straps to fit...
Thanks for all the help tonight. Does every marque have a forum like this??? If not, they're missing out.
-Jeff
p.s. Hey AW, how did you get your bumperettes off? That was part two of this project, but they are glued on there good. I'm afraid to rip at them too hard. Any advice?
Old 04-21-2005, 09:44 PM
Banned
fastpat's Avatar
Originally posted by awcayenne
here's my dansk.
aw
I was afraid someone would say that about the Dansk two outlet muffler. Isn't there a Dansk rep that posts on this forum? What does he have to say about this design/assembly error that's being sold?
Old 04-22-2005, 08:35 AM
Banned
fastpat's Avatar
-Jeff
Glad to see you got it on OK, how did you deal with the outlets being at different angles?
Old 04-22-2005, 09:20 AM
Bye, Bye.
Scooter's Avatar
And I was going to post that I thought you had the wrong muffler, then I see that you got it on. Anyway, if this question comes up in the future, keep in mind that the 3.2 muffler is different than an SC muffler, in that the 3.2 has an indention to accommodate a bypass (edit: crossover) pipe, where the SC does not. I found this out the hard way...so read and benefit from my mistake.
I am glad it worked out, the dual out Dansk on a 3.2 sounds great.
Elvis has left the building.
Old 04-22-2005, 09:45 AM
Light,Nimble,Uncivilized
Originally posted by Scooter92
And I was going to post that I thought you had the wrong muffler, then I see that you got it on. Anyway, if this question comes up in the future, keep in mind that the 3.2 muffler is different than an SC muffler, in that the 3.2 has an indention to accommodate a bypass pipe, where the SC does not. I found this out the hard way...so read and benefit from my mistake.
I'll second both comments! ('cuz it was I who bought Scott's single in - dual out)
FWIW my passenger side outlet pipe also hangs ~.5 inches lower than the drivers side.
Drago
'69 Coupe
R #464
Old 04-22-2005, 10:21 AM
Nine9six's Avatar
I had posted earlier on the installation of a 1 in, 2 out Fabspeed. I recommended exactly what you did for fitment. Good job, BTW!
Always, when installing aftermarket headers, SSI, pre-muffler, sport mufflers, its a good idea to loosen items within the chain and tighten in increments for quality of fitment.
Now turn down the radio, and enjoy the real music.
Cheers.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-22-2005, 10:32 AM
Limbo
Slider79SC's Avatar
Jeff,
To get the bumperettes off, you sometimes have to put the nuts back on (not all the way) and hit then with a hammer in order to loosen the bumperettes from the bumper. They do seem like they are glued on but they are not.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 04-22-2005, 12:35 PM
Banned
fastpat's Avatar
Ralph
Hey Ralph,
Is that the Dansk pre-muffler I see on your car in that photo? This thread has been very informative, by the way.
Old 04-22-2005, 02:36 PM
Originally posted by fastpat
[B]Hey Ralph,
Is that the Dansk pre-muffler I see on your car in that photo?/B]
Hi Pat,
Yep, that was the Dansk stainless pre-muffler I used to run. Sold to a local Pelicanite.
Ralph
Old 04-22-2005, 02:51 PM
hey jeff, hit them with a rubber mallet. also helps to remove the rear valence first. aw
Old 04-22-2005, 03:01 PM
Where did you get the muffler? What is the P/N? The earlier version did not have the relief for the heater cross over pipe. Don't ask how I know, but I think I've seen this before.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 04-22-2005, 03:47 PM
