Longhoods Unite!
"Squeegee" Seal and weatherstripping help
'70 911T Targa, doing the fun job of new weatherstripping...
The "squeegee" seal on the outside of the glass that slides into the chrome window sill...it stinks, i got the old brittle one out finally...but are there any tricks to sliding the new one thru?? should i use soap or gasoline or anything slippery?? any advice would rule. Thanks in advance. Joe. My targa isn't worthy enough yet to be on the forums yet, needs more work. but soon...soon.
1970 911T -- Neglected, oil burning problem, batman smoke 1974 914 2.0 Weber'd -- new project!! **My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
I'd try armorall as the "slippery"...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Use silicon grease. Won't hurt the rubber.
69 911 2.3Ez 85 928S |
Much easier if you remove the outer metal window trim. Use a nylon or plastic wedging-type tool and lift the trim upwards so the spring retaining clips (seven clips and 3 plastic locaters I recall) clear the holes in the door. In a pinch, fashion an equivalent tool by wrapping a single layer of plastic electrical tape over a thin, broad-tip slotted screwdriver and pry upwards evenly. Do not attempt to remove by sliding the trim off. Needless to say, be careful with the paint in this area.
However, try the silicone spray, Armorall and Dow 111 grease tricks first. |
Re: "Squeegee" Seal and weatherstripping help
Bring it on......... |
3.4 Bigger is better
Just went out and got mine off the car. I used a plastic screw driver used to work on electronics, worked great. The old squeegee slid right out haven't tried to put the new one in yet. Need to clean it up first. Learn something new about the car every day. Joe thanks for starting this thread, perfect timing. Would be great to see the pics of your car.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
