Ho Hum 74's Avatar
Dimensions of a 911
Found a trailer that's very light (680 lbs) but small. Not sure if the 911 will fit. Does anyone have the dimensions of a 911?
What I'm looking for is the width (to outside or tires) and the length of the car...
I'm not at home right now (on the road) otherwise I'd just crack out the tape measure.
Old 04-26-2005, 07:55 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
I know for an early short wheelbase 911 you need about 14 feet.
I figure you would be safe with a 18ft by 8ft trailer. Not much side room or extra length but is should fit.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 04-26-2005, 08:19 AM
MBruns for President
JeremyD's Avatar
Re: Dimensions of a 911
Wheelbase: 2268 mm 89.29 in
Track front: 1371 mm 53.97 in
Track rear: 1359 mm 53.50 in
Length: 4290 mm 168.89 in
Width: 1613 mm 63.50 in
Kerb weight: 1080 kg 2380.98 lb
Old 04-26-2005, 08:26 AM
Ho Hum 74's Avatar
Thanks Jeremy
Old 04-26-2005, 08:36 AM
