Gilles RoW 88 Carrera coupé |
It will clean up like new if you first clean the grease/oil off with thinners then immerse the strap in pickling vinegar (10%) for a couple of hours.
1986 Targa Guards Red 2021 MT09 SP |
Best, Nick
1979 911 SC |
PCA Member since 1988
I don't care if my ground strap is greasy. IMO, it helps prevent corrosion of the strap and at the contact points. You do you.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
John W
Totally agree with Wazzz, a dirty ground strap is ok. Be sure it isn’t frayed as that reduces the current flow capacity and is bad. The electrical contacts must be clean. Don’t use dielectric grease on the contact places, use a conductive grease.
