warpspd's Avatar
Send a message via ICQ to warpspd
3.6 conversion throttle cable alternatives?
I am using a timmins throttle cable setup on my 95 3.6 conversion but it seems like it is not getting full throttle with pedal to the floor. I see on timmins site that there is some sort of a bell crank mod does anyone know exactly how it is modified or if there are any better alternatives out there
Ryan
Cimarron region PCA member
98 Boxster
Old 04-25-2005, 09:31 PM
frencjas's Avatar
IIRC you add 1" of length to the bell crank arm with the Timmins kit.
Jason
Keep Right Except to Pass!
2000 Audi S4 Quattro Non-Sunroof
1989 BMW M3 (sold 12/06)
1977 911S Wide Body 3.6 Varioram (sold 11/05)
Old 04-25-2005, 10:35 PM
Can anyone post some closeups of completed throttle cables of different variants, i.e. Timmins or otherwise?
Old 04-25-2005, 10:38 PM
warpspd's Avatar
Yeah I figured that you added a little on the end to get better leverage on the cable. Can you post a pic? I did not get the modified bell crank so that might be partially the problem. Has anyone ever modified the bell crank themselves?
How about some pics of alternative installs or whatever ya got..
Ryan
98 Boxster
Old 04-25-2005, 10:43 PM
wot wot is offline
wot's Avatar
Hi
There is no need to use the Timmins cable or the expensive Patrick Motorsport cable, you can modify the original linkage set up from your old engine, I use this on my 95 993 engine and it works great.
You need to lengthen the bell crank on the engine-mounted part and on the throttle body, but you end up whit the original solution and it is basically free.
Bill Verburg did this on his first conversion and I believe he has some pictures on one of his Web's
Erik
82 SC 3,6 73 RS Look
Old 04-26-2005, 12:14 AM
tholyoak's Avatar
Check out
My solution to 3.6 swap throttle cable
Todd
1989 911 Targa
Old 04-26-2005, 10:02 AM
