915/40 gear ratio
Hello,
Does anybody know of a list of the existing 915 types against the stock gear ratios used? I have a 915/40 tranny (mag case from a 2.7 ltr 1976) and would like to know the stock ratios and ring/pinion in there. With seach, I couldn't find that info. Thanks in advance, Walter |
Walter,
Welcome to the Forum. A 915/40 is a 1975 5-speed 911S, 911S/C (USA). If as originally delivered its gearing is: 1st – 11:35 2nd – 18:33 3rd – 23:29 4th – 26:26 5th – 28:23 R&P – 8:31 It should have a serial number in the form: 715XXXX starting with 7150001 Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
'76 US 2.7 911 used a 915/44[list=1][*]11/35[*]18/33[*]23/29[*]26/26[*]28/23[/list=1]
w/an 8:31 r/p electric spoeedo
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 04-30-2005 at 05:32 AM.. |
Thanks guys,
You rock! Most of the serial number has been grinded off from shoving the case around the garage floor, but the type number should be conclusive enough I guess. Tnx, Walter |
