austin552's Avatar
Question Boxter 3.2l install
How hard(time/$$) would it be to install a boxter 3.2l in my 74'S?
1974 911s
Old 05-01-2005, 07:52 AM
AFJuvat's Avatar
Extremely difficult and likely hideously expensive.
Assuming you had a good used motor, you would still need some method of plumbing the cooling system, plumbing for a hydraulic clutch, Wiring (Motronic\CAN bus).
Further, you would need a boxster transmission - a 901\915\930 transmission would not bolt up to a boxster motor.
You would also need to find some method of mounting the engine\transmission. - the boxster motor uses a completely different mounting system.
You would probably be money ahead just to buy a boxster.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-01-2005, 07:59 AM
Send a message via Yahoo to Lukesportsman
IF you were to go to the trouble, 996 engines which would at least be in the correct orientation in regards to tranny and are not going for that much. Same money, same high effort, has been done before with possibly great results. I know, the Boxster engines are going for reallly cheap. I think it really depends on how much of the Boxster you can get (ecu, axles, tranny, wiring harness). If you can build a kitcar and install a Porsche engine, I don't know why you could fab one up to fit in a Porsche. Figure, guys have put 928 engines in 914's.......SURE a 996 style engine will fit.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 05-01-2005, 08:23 AM
austin552's Avatar
Yikes!! never mind!
Sounds like it would be harder than a small block chevy install.
1974 911s
Old 05-01-2005, 08:24 AM
austin552's Avatar
A 996 engine would cost allot more than a Boxter motor wouldn't it?
1974 911s
Old 05-01-2005, 08:32 AM
