pjv911's Avatar
Send a message via AIM to pjv911
Does anyone make a prefabed rear shock crossmember ?
I want a weld in type custom rear shock crossmember that will take the place of the stock unit . I want more strength since im going with coilovers and a heavy engine/tranny combo (c2 turbo engine and a G50). Anyone have any leads or who to call ? Im sure I could make it myself but my time is harder to find than $$ . Ive been sitting on this project now for 18 months and have to get this finished soon .
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 04-29-2005, 08:09 PM
pjv911's Avatar
bump
Old 05-02-2005, 05:50 PM
Kurt,
Check with Doug Arnao at VCI in Dover NJ. I know he makes a custom one. Look on his website under customer cars
Dan Jacobs
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 05-02-2005, 06:22 PM
pjv911's Avatar
I got his # and will give Doug a call tomorrow . Thanks Dan
Kurt
Old 05-02-2005, 07:06 PM
Grady Clay's Avatar
Kurt,
I would consider buying a new Factory part and modifying it both internally and externally to reinforce it and make it fit your needs. I think the latest part that will fit is 964.501.075.00 “Rear Axle Cross Support.” Clearly a 993 part won’t fit.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-02-2005, 07:32 PM
pjv911's Avatar
I do have one from a 911sc and could easily add the truss (supports) . Im just interested in my other options . Im assuming that the area between the firewall and crossmember will not be easy to properly weld since there is no clearance. For that reason Ive been seeking other options before I begin.
I will not be using a roll cage and all the custom types ive seen so far look dependent on a cage .
Kurt Williams
Old 05-02-2005, 07:40 PM
Grady Clay's Avatar
Kurt,
When did Porsche weld the leading edge of the Rear axle cross support to the firewall?
BTW, do you know anyone in your neck of the woods interested in a Bluebird (510)? Unmolested ’72, 2-door, 112K, original paint, 2-owner, no rust California car.
Best,
Grady
Old 05-02-2005, 08:06 PM
pjv911's Avatar
Maybe me . I have a hot nissan 3.0 turbo engine(354 rwhp) looking for a home . Also I like the simmple lines of those cars . Is it a all orig car or is it ready for a motor swap . Im interested . Send me more info . kurt@digitalprovisions.com
As for the welding ? Are you saying that the area toward the front of the car directly behind(not to) the firewall is not welded ? I have not removed mine yet but the SC unit looks like it was spot welded all around .
Old 05-02-2005, 08:13 PM
pjv911's Avatar
Grady I think I would have even more interest if the car was all or close to original . Let me know the details .
Kurt
Old 05-02-2005, 08:14 PM
