Noel's Avatar
Originally posted by Zeke
I like the "soft" approach to this. But, I don't know if the various sanctioning bodies feel the same way.
I just looked in the PCA club racing rulebook. For what it's worth, under the "Safety" section, paragraph 23 states:
"All cars must have a tow hook, strap, or other suitable device in both the front and rear."
Since the word "Strap" is mentioned, I assume the safety belt towing strap proposal would be acceptable. As long as any of the towing devises are appropriately marked with the familiar tow hook decal, it will enable the track workers to easily identify the strap. In my case, I will mount the tow decals to magnetic material so that they can be more easily installed and removed.
Another reason I like the strap idea is that it can be tucked in behind the bumper when I'm not at the track.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 05-06-2005, 04:39 AM
Non Compos Mentis
The SCCA requires a 2" minimum opening. The under car hooks are not big enough.
Old 05-06-2005, 06:58 AM
North Coast Cab's Avatar
Noel,
I ordered a few of the climbing runners rated at 5,000lbs to mess with. Hopefully I can find a spot to mount that is very discrete. I'll keep you posted.
John
1985.5 944 GTS
Old 05-07-2005, 05:56 AM
Noel's Avatar
Originally posted by North Coast Cab
Noel,
John
John,
I look forward to reading your report and seeing the photos.
Noel
Old 05-07-2005, 08:32 AM
Noel,
I received the nylon runners today. They are a sewn loop that's about 9" in diameter. With a decent mount spot it could be a nice solution. However, I don't see an easy mounting spot but I'll try to find something.
John
1985.5 944 GTS
Old 05-11-2005, 04:55 PM
Noel's Avatar
Sounds good.
For the front, I was thinking that bolting it to the place where the bumpershock meets the body would work. Then you could thread the strap through the space between the bumper and the front valance. It seems like it would be a straight shot.
Or what about just slipping it over the bumper. You would have to disconnect the bumper to slip it around, but this may work too.
I look forward to hearing about your results.
Old 05-12-2005, 05:10 AM
Noel's Avatar
I just saw this new Weltmeister Product that looks like it would work for the rear. The list price is about $80. I don't know if it is in the Pelican Parts catalog yet. What do you guys think?
Old 05-12-2005, 08:58 AM
ipapilot's Avatar
I just saw this piece myself in the new Performance Products catalog, doesn't look too bad for the money...
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 05-12-2005, 10:10 AM
Alter Ego Racing
ErVikingo's Avatar
I have one made by GW Motosports for sale. PM me
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 05-12-2005, 01:59 PM
As a climber I can tell you that climbing-spec webbing (also referred to as "military-spec") is plenty strong to pull a car. Spectra (a stronger form of webbing) is even beefier, yet lighter. Make sure to get bar-tacked loops of it rather than pieces of it that you would have to knot (the knot is a weak point). The biggest drawbacks here are that nylon webbing does not do well with heat or friction, with spectra having a lower meting point than normal webbing.
Old 05-12-2005, 03:36 PM
hmd hmd is offline
Hi everyone,
I got a place to computer laser cut a towhook for early 911 front bar. If anyone interested in getting one let me know they are made from 4mm thick high strength steel and to do a run of 5-10 would cost about US$30 each.
76 Carrera 3.0 (Group Sc)
Old 08-09-2005, 10:26 PM
PCA7GGR's Avatar
The Performance Products rear towhook/jackpad is an ideal solution for the rear. But, as in my "case", it may require you to lengthen the mounting studs on the engine case. This is not a complicated process but time consuming since the engine needs to be supported to remove the muffler, rear engine tin, engine cross-brace and engine mount plate. Once you do that, you then double nut the stud, extract it, replace the studs with longer ones and then reverse the process.
The front towloop was a bit simplier. Using aluminum stock and longer bolts, I mounted it on the front suspension where the tiedpwns were also mounted
Sergio
The GT Lid Whisperer
PCA 42yrs / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 08-10-2005, 02:27 AM
}{arlequin's Avatar
what's it look like?
dave
1973,5: one two thweeee!
no.don't.stop.
Old 08-10-2005, 05:11 AM
Alter Ego Racing
ErVikingo's Avatar
Hey Dave,
It's long gone now.... Noel might be able to post pics.
Cheers, Juan
Old 08-10-2005, 06:40 AM
Noel's Avatar
Here is a photo of the one that Juan mentioned:
Old 08-19-2005, 03:12 AM
}{arlequin's Avatar
oh wow... nice looking piece
dave
no.don't.stop.
Old 08-19-2005, 06:26 AM
arrivederci's Avatar
I saw one yesterday for the rear that was a lot like the ones above. But the key difference was that the hookup point was actually a large U bracket that had been welded onto a plate. The U bracket was long enough to extend past the muffler so there was no interference. This could be made pretty simply for less than $20.
- '72 911T
- '81 911SC Euro
Old 08-19-2005, 06:45 AM
Cool tow hook
Originally posted by hmd
Hi everyone,
I'd be in for one of these at $30ish if you do a run.
1979 911SC
1978 911SC Euro
Instagram: collierbrands
Old 11-28-2005, 02:27 PM
hmd hmd is offline
PM Noel he may have one.
Old 11-28-2005, 02:31 PM
Noel's Avatar
Yes I still have a few left. $35ea +shipping which is what I paid. One note though, new holes must be drilled as the manufacturing company that made them folded the hooks in the wrong direction making the existing predrilled holes unusable. I've already drilled a couple with a hand drill and it is quite easy.
Old 11-29-2005, 04:30 AM
