Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
AC compressor doesn't spin
964.
There's no freon in the system at all. It's leaked out long ago. I didn't use it in that state though. I want to fill her back up with some stop leak and refill it but I can't as it won't spin.
It worked before. Do they have trouble coming on when empty, and if so what do I do?
-kb-
Old 05-17-2005, 07:06 AM
Nitrometano's Avatar
If the system have a pressure switch, you will need to jump the cables to activated the compressor. If not have a pressure switch, take the cable that exits from the compressor (I think is black color) and jump it to a 12 volt souce. You can take the energy from the rear engine fuse blocks.
If you want to fill the system, you need to make a good vaccum. Then recharge with refrigerant. Never turn on the compressor with the system in vaccum or you will damage it.
Good luck!!
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 05-17-2005, 07:19 AM
Wider is Better
wholberg's Avatar
The compressor should spin even when the system is empty.
If the clutch is spinning and does not lock in when you turn the AC on, the clutch, or clutch relay, is bad.
If the clutch engages and the belt squeals like a banshee, then the compressor is frozen.
Bad clutch is the most common.
Wider is Better
Old 05-17-2005, 07:21 AM
scottb's Avatar
This is only true if he doesn't have a high/low cut-off switch.
1984 Targa
Old 05-17-2005, 08:05 AM
The clutch doesn't lock and that appears to the problem. I guess it appears as though the on switch isn't flipping on; so maybe the clutch is bad. I'll have to test the terminals for power when the switch is on. If I have current, then the clutch is bad. Thanks.
Last time I left it on for a while, farted around with it, and it started going...this time, no go.
Bummer...
-kb-
Old 05-17-2005, 09:02 AM
Detached Member
Hugh R's Avatar
Like nitro said, jump the clutch wires to a hot connection and see if it locks and spins the compressor. Just make sure its a beefy power source. On a 91 you probably have a hi-low pressure switch which has to be jumped if low on freon.
Hugh
Old 05-17-2005, 09:09 AM
ruf-porsche's Avatar
Black Death of a Compressor.
Non use and an open system equal frozen compressor which translate to BLACK DEATH
http://www.acsource.com/articles/bdeath.html
Old 05-17-2005, 01:59 PM
Wider is Better
wholberg's Avatar
Thanks. I learn something new on this board every day!!
Wider is Better
Old 05-17-2005, 02:27 PM
You want to use sealer and then recharge with refrigerant? Not a good idea, since the sealer clogs up the expansion valve, the reed valves in the compressor, and generally cause havoc in the system.
For more information, see the article at:
http://www.autoacforum.com/messageview.cfm?catid=20&threadid=9173
Old 05-18-2005, 03:10 AM
