Idle speed w/AC on
I've got a 1984 Carerra, and when I turn on the A/C the idle speed drops to 800rpm from 880. I thought it should increase 50 rpm. Anyone have any insight? Thx.
Old 07-30-2009, 01:41 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
drops due to the load you just added
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 07-30-2009, 02:25 PM
pete3799's Avatar
Your turning a compressor hence lower RPM.
Pete
79 911SC RoW
Old 07-30-2009, 02:27 PM
The AC compressor status goes to the DME. What it does with it??? Your guess is as good as mine.
Rick
88 Cab
Old 07-30-2009, 02:52 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap Normal.
Hey do you have a Chip Mod? 84 RPMs should be 780-800 RPMs. If chipped it should be 880.
'85 Carrera Targa
PCA/POC
Old 07-30-2009, 03:49 PM
no chip mod, but I am about to order Sw chip. Ive done everything I possablly can do to get this engine running smooth at idle. All sensors are new or adjusted no vacume leaks, complete rebuild 5000 miles ago, valves adjusted. I figure that when the A/C is turned on that the DME will compensate with a higher RPM with the increase in load.
Old 07-31-2009, 07:43 AM
