| Registered |
				What causes Back firing on deceleration
			Like when coasting down a hill in first  gear? Tried a search but did not find anything
|  05-13-2005, 10:47 AM |
| Registered |
			Too rich.  Unburnt fuel is getting into the exhaust and igniting.
				__________________ '76 911 Carrera 3.0 | ||
|  05-13-2005, 10:54 AM |
| Registered Join Date: Dec 2004 Location: Suwanee, GA
			Is this like a big backfire or more of a rumble like an 18 wheeler jake brake type
				__________________ 1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler | ||
|  05-13-2005, 11:37 AM |
| Registered |
			My 911 exhibits the same type of thing... some backfiring when decelerating in gear.   I think it's something to do with the distributor/points. Once I shift into neutral, it goes to idle and idles normally. Oh, and mine's more like a gurgle-gurgle-pop-gurgle-pop-pop... kinda like the 18 wheeler thing. Not real loud backfires, but clearly audible 'pop's.
				__________________ Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" | ||
|  05-13-2005, 11:43 AM |
| Registered Join Date: Aug 2003 Location: RI
			I do not think at has anything to do with your points. Sounds like fuel mixture as stated above. When you decell in gear your pulling a vacume so you are getting some additional fuel. If your mixture is rich you are sending unburned gas through the hot exhaust causing the sputter/popping thing.
				__________________ Silver 1980SC Euro coupe | ||
|  05-13-2005, 11:54 AM |
| Registered |
			Ron, that makes sense.  I think my engine is running a little on the rich side.  I have not gotten to (or even figured out) the mix adjustment.  I do know the distributor in my car is not the correct one, so the cap and rotor I got are not the correct ones either. Apparently a PO put a Bosch distributor from a slightly older engine on it. It's got a two peice points setup. I ordered the two peice points, and what I think are the correct cap and rotor for it.
|  05-13-2005, 12:25 PM |
| Registered |
			leaks in the exhaust system also contribute to backfiring.
|  05-13-2005, 12:26 PM |
| Wider is Better | Quote:
 An engine does not have to run rich to backfire under heavy enging deceleration.
				__________________ Wider is Better | ||
|  05-13-2005, 12:33 PM |
| Registered |
			Well, the exhaust leaks would make sense.  The undercarriage looks pretty... well.... WORN on mine.   Eventually she'll get new heat exchangers and exhaust/muffler stuff.
|  05-13-2005, 12:35 PM |
| Registered |
				It is a back fire plus some rumbling/gurggling
			I coasted to a stop in gear the other day and a guy thought I was doing a drive by. He gave me a pretty funny look. I does not happen all the time.
|  05-13-2005, 12:44 PM |
| RETIRED | Quote:
				__________________ 1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel | ||
|  05-13-2005, 12:54 PM |
| Unregistered Join Date: Aug 2000 Location: a wretched hive of scum and villainy
			On mine I went all the way through the exhaust, all new gaskets etc and found no leaks. It was like the jake brake thing, not loud popping, just rumbling.  Since the repair to the lamda sensor fixed the noise (or at least compensated for whatever was wrong) I'd have to say mine was mixture related. | ||
|  05-13-2005, 01:15 PM |
| Registered Join Date: Jan 2003
				 | Quote:
				__________________ Tailwagger NER/NCR PCA, SCCA, NASA, COM 2000 996 C2 Aero Brumos 59 Special Ed. 1970 911 3.2L RSR | ||
|  05-13-2005, 01:45 PM |
| Registered Join Date: Feb 2004 Location: Houston
			Adjust your micro switch.
				__________________ Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door | ||
|  05-13-2005, 03:03 PM |
| Registered Join Date: Jul 2001 Location: Wilmington, NC  USA
			There is another thread that asks the same questions.  Your mixture may be correc t and it will still happen.  It happens because there is incomplete combustion in the cylinders on overrun conditions.  Overrun condition is when the RPM is high but you have your foot off the accelerator(throttle closed).  The microswitch on the early MFI and Zenith carb cars activated a solenoid to stop this when the throttle is closed and RPM s are aboce 1500 RPM for MFI and 1350 for the Zeniths.  Under these RPM limits the RPM tranducer(speed switch) deactivates the solenoid and the car works normally.  TO stop the gurgle(backfires) put in your clutch and the RPM will drop and the overrun condition stops.  On Zenith cars the solenoid actually adds fuel to increase combustion to stop the backfires.  Hope this helps. JIM
				__________________ 69 911 2.3Ez 85 928S | ||
|  05-13-2005, 07:25 PM |
| Back in the saddle again Join Date: Oct 2001 Location: Central TX west of Houston
			2 things, exhaust leaks, which in my experience make a few big backfires, and gas in the exhaust which is usually the popping and gurgling that some cars exhibit.   the first should be fixed the second is normal and expected for most older cars like SC's and older, but is not normal for 3.2L cars and newer.
				__________________ Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa  SOLD 2004 - gone but not forgotten | ||
|  05-13-2005, 08:31 PM |
| Registered Join Date: Apr 2005 Location: Park City, UT
			Another data point - after installing SSIs and Mony muffler this now happens (gurgle gurgle pop pop [small pops]).  No exhaust leaks.  I chalked this up to something different between the new exhaust and the old exhaust since every SC (and even Carrera) that I have seen/heard with SSIs or B&B exhaust does it.  Especially noticable at autox. I kind of like it
				__________________ '82 911SC racecar '05 WRX STi | ||
|  05-14-2005, 04:44 AM |
				 | Quote:
|  05-14-2005, 06:31 AM |
