trouble lowering rear suspension....did not move
I tried to lower the rear of the 87 the other day... and it did not move at all. I loosened the proper bolt and rotated the eccentric bolt according to Waynes book......NOTHING.
Am I an idiot, or is there something I am missing? What might be broken or hung to cause this?
Anyone else encounter the same?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 05-13-2005, 05:23 PM
Friend of Warren
Are you sure you adjusted the right bolt? It's the one that uses the 36mm thin wrench.
Kurt V
Old 05-13-2005, 05:50 PM
I will be trying again tomorrow, but I am reasonably sure I was following the normal procedures. Using the correct bolts and such....real strange.
Old 05-13-2005, 05:54 PM
Hi Ken. Not sure how low you want to go, but I recall from the meeting last October, your car being fairly high in the rear. You may need to reindex the rear bars in order to get within the range you are looking for. Then use the fine adjustment on the spring plates to get it perfect.
I JUST lowered mine the other night. After going up & down with the car three times I finally got it right. I use to be able to get my fist between the tire & fender, now I can barely get my hand in there flat. I have the old solid spring plates so its a bit more difficult for me to get it 100% balanced. I swapped in 28mm bars while I was at it. -John
'73 RS Clone (flared, lowered, backdated, swapped)
'72 124 Spider (newest project; shaved & lowered cruiser)
'97 328ic (wife's toy)
'05 3500HD D/A (tow vehicle)
Old 05-13-2005, 06:07 PM
coloradoporsche's Avatar
Adjusting the height takes some time...and some Karma. Seriously, I have spent the better part of the last 6 months adjusting the height on my 79SC, and I swear there are cosmic forces at work that you simply cannot predict or control.
Did you adjust both sides? If the car is not properly balanced, it is possible to change the height adjustment on one side without seeing any change in height, which indicates there was little or no weight on that wheel to begin with. If the answer is 'yes' and/or you have maxed out the adjustment on the spring plate, then you need to re-index the torsion bars as Flying Toaster suggests.
It's also a good idea to jump on the front and rear bumpers afer each adjustment to settle the car. Even better to drive it around the block.
Try searching under "tripod". By using this method you will save a lot of time adjusting your ride height.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 05-13-2005, 06:20 PM
I agree. I went up & down the street quick after I "thought" I was finished. The car settled & sat a bit differently than how it looked after just rolling it in the garage. Definitely do both sides. One side doesn't make much of a difference. If you do end up reindexing, hope you have air tools to make the job quicker. If all else fails, throw wrenches & kick the dog.
-John
Old 05-13-2005, 07:22 PM
John,
I do have air tools, and a dog. Maybe a combo of both will get it right.
I will be trying this afternoon if you are visiting your in-laws, you can feel free to stop by and laugh at my progress. This is more of a PITA than I expected. Ken
Old 05-14-2005, 04:22 AM
Something not mentioned here.....stock...from the factory...the ride height adjustment bolt ( for the two piece rear spring plate) is set all to one side ( not in the middle of the slot) ...so the only adjustment allowed is RAISING. It is meant to compensate for spring sag over time.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-14-2005, 06:00 AM
Also...to get away from the "Karma" thing....the rear ride height can be adjusted ( predictably) using my method that Thom Fitzpatrick put into a nice little software package.....do a search .
Here's one thread I found --> Ode to the Ferch Method
Wil
Wil Ferch
Old 05-14-2005, 01:16 PM
Thanks Wil & John.
I was able to complete the bilstein sports front and rear yesterday, but nothing on te ride height. I will try to find a good shop near by to lower and align it in one shot.
Old 05-15-2005, 06:06 AM
Somatic Negative Optimist
Gunter's Avatar
ken_xman: Factory height & specs are quite different. If you go to a shop, make sure you know what height, camber and toe you want beforehand. Go to a shop that is familiar with the suspension and lets you be right there. Have them set the adjuster eccentric in the middle of the torsion plate and set the height by indexing the torsion bars. That way you have some fine-adjustment up or down. A Porsche shop will take about 8 hours to align and corner balance. I set mine at the height I wanted using the above, set the camber I wanted, and then went to a shop to finalize.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-15-2005, 06:51 AM
The ride height adjustment should not be beyond my means. Maybe I will try to re-index the bars and stop jerking around with the bolt adjustment.
I also have an issue with the front..... the foward most portion of the front torsions, has the mount bracket and tow hook combo... that is bent and needs replacement so they need to come out too.
Old 05-15-2005, 06:58 AM
Gunter's Avatar
The Bentley manual will be a great help to you for indexing the torsion bars. Make sure you understand why there are 40 splines inside and 44 outside. I found the easiest way was to raise car, remove wheels, set on jack stands, disconnect sway bar, rear shocks, let everything hang loose, put floor jack under spring plate to take spring load, remove bottom bolt on spring plate cover, lower the jack, mark the position of the spring plate by scribing on the body, remove spring plate cover, remove torsion bar, index to achieve height, put everything together. Go for a spirited run to settle the shocks. It will take several tries; Get the Bentley manual.
Old 05-15-2005, 07:39 AM
