Send a message via AIM to tony77targa
7 and 8 x 15 fuchs fit on a 77 911s ???
Can I squeeze these on my 77 911s without rolling fenders and rubbing issues??
Thanks in advance for any input......
Tony
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 05-14-2005, 05:17 PM
Bird. It's the word...
Fishcop's Avatar
You can definitely fit the 7s in the front. I've got SC flares on my 69 and the 8s fit comfortably... With some negative camber the 8s "should" fit under your mid-year flares. I'm sure someone who knows better will chip in.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-14-2005, 05:39 PM
thanks John........ anyone else have 8x 15 on a narrow body?
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 05-14-2005, 07:53 PM
8x15 on a narrow body will be very difficult w/ the standard Fuchs offset. If you roll the fenders, dial in about 2 degrees negative camber & select tires carefully it can probably be done (dependant on car).
Even with 7x15's you may get rubbing.
Old 05-14-2005, 08:05 PM
I was looking at 7X15s all around for my 75. Since 7s were stock on the rear that year I don't see a problem. But has anyone had theml them rub in front?
Jack
Old 05-15-2005, 05:59 AM
hhhhhhmmmmm now Im even more confused
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 05-15-2005, 08:48 AM
Mark Wilson
Guest
Posts: n/a
Re: 7 and 8 x 15 fuchs fit on a 77 911s ???
No.
7's are max (15 or 16) and may only fit the rear with rolling and camber adjust. It depends on how straight your car is and what size tires you put on the 7's.
Old 05-15-2005, 09:12 AM
Bill Verburg's Avatar
there is no 8x15 Fuchs the will fit a narrow 911,but 7 & 8x 16 have been fitted successfully, you need the +23.3mm o/s for both 7 & 8
Ingos 7 & 8x 16
Bill Verburg
Old 05-15-2005, 03:34 PM
Todd Simpson's Avatar
Jack-7's aren't stock on a '75, they used 6's all around.
Here's another thread with the trials and tribulations of wider wheels on the rear of a narrow body.
Photos of 15x8s on my narrow body '74
Old 05-15-2005, 04:43 PM
Zeke's Avatar
In addition to that link, here's mine. I also have some 8 x 15's and there is no way. Not if you want the car any kind of low. They stick out from the body one inch w/o the tires on. 7's are as far as I could go. I have explored thoroughly the prospect of a custom backset and still could only manage 7.5 inches w/o rubbing on the spring plate alignment adustment nuts.
60 series tires would help a little.
Old 05-15-2005, 05:00 PM
oooooHHHHHHHkkkkkK I think I have a difinitive answer here....
I am definitly not buyin the 7x8 fuch to try to fit to my car...
Thanks everyone for the Help!!!
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 05-16-2005, 02:50 AM
aus911's Avatar
I just put 7's on the front of mine, with 215/60/15 tyers, they rubbed badily so I changed the tyers to 205/60 /15 hope this has fixed my problem, will let you know
Old 05-16-2005, 04:25 AM
Fishcop's Avatar
Aus, you may want to consider dropping to a 50 series profile. I've 7x15 on the front with no problems.
John Forcier
Old 05-16-2005, 04:43 AM
