H.G.P.'s Avatar
After warm-up, is there such a thing as an ideal RPM?
This is a 69 911 E. After proper warm-up I still do not know the ideal proper RPM.
1. For instance, say I'm driving on a normal highway interstate that posts 65 mph. Where would I keep the gear and RPMs.
2. Also, at certain RPMs does the transmission work harder?
Thank you.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 05-15-2005, 05:51 PM
bigchillcar's Avatar
not sure where the peak of the power band is for a '69 e model, but it's around 4k in my 2.7. not sure either if you have a 4 or 5 speed tranny in your car, but i'd think the highest gear for cruising is appropriate at 65 mph, unless you're in traffic and anticipate passing, changing lanes, etc. in that case, stick with the next highest gear until you're in a position to simply cruise and assuming the temperature of the car isn't prohibiting an overly high rpm. you definitely don't want to operate around town in lower gears that don't allow at least about 3k rpms...these motors actually need the higher rpm's to keep air moving over the heads for more efficient cooling and also so as not to 'overload' the tranny by making too high of a gear work with too few rpms..hope this helps.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-15-2005, 11:50 PM
Gon fix it with me hammer
svandamme's Avatar
depends on what you want, fun , or low fuel consumption
you want fun , then pick the gear that will facilitate the best accelleration
you want fuel consumption to be low , then pick the highest gear you can without lagging the engine
2
redline is definately better on the tranny than idling
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-16-2005, 12:20 AM
ditto for top gear
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-16-2005, 01:58 AM
H.G.P.'s Avatar
Originally posted by svandamme
2
A. What exactly is "redline" anyway? I did a search and found no definition. It can't be the redline on the tach can it? I mean 7 grand cruising ??
B. How is this easier on the transmission too?
1969 911 E Coupe
Old 05-16-2005, 09:10 AM
drag racing the short bus
dd74's Avatar
I don't know if 7,000 RPMs is exactly cruising - I'd call it racing.
The Terror of Tiny Town
Old 05-16-2005, 09:34 AM
Keep that engine over 3K rpm, and every chance you have floor it to blow and clean the conbustion chamber, valves , intake & exhaust.
Old 05-16-2005, 09:50 AM
Re: After warm-up, is there such a thing as an ideal RPM?
do all your shifting between 3-4k rpm and keep top gear cruising above 3.2k rpm and your engine will love you.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-16-2005, 09:52 AM
svandamme's Avatar
sar·casm ( P ) Pronunciation Key (särkzm)
n.
1. A cutting, often ironic remark .
2. A form of wit that is marked by the use of sarcastic language and is intended to make its victim the butt of contempt or ridicule.
3. The use of sarcasm. See Synonyms at .
wit .
Stijn Vandamme
Old 05-17-2005, 01:33 AM
Peak HP on a 69E is at 6500 RPM. Rev limiter kicks in at 7120 RPM if you have the stock rev limiting rotor installed. The 69E manual says do not go below 1500 RPM in any gear except first. So after first gear anywhere between 1500 and 6500 is where you want to be. As a practical matter the torgue on the 2L engines does not really appear until you are above 3000 RPM. I try to keep my RPMs above 3000 in every gear with fun excursions to redline as I shift up. Of course I probably get the worst gas mileage but winding the short strok Porsche engines to redline is a lot of fun. Of course you are probably exceeding the speed limit after second gear(65MPH) but so what. Shift when you want and most importantly have fun.
69 911 2.3Ez
85 928S
Old 05-17-2005, 09:18 AM
