When to rebuild calipers?
I'll be doing a flush, replacing the pads, inspecting the rotors, and replacing the brake lines but how do you know when it's time to rebuild your calipers?
The brakes work ok, but I have nothing really to compare it to.
68 911L |
On mine it was readily aparent by the dust seals being malformed and pretty trashed, but sometimes they may need it before that.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
I rebuilt mine when they started "dragging" - Not releasing all the way...That was when the car was about 25 years old....This will vary with whatever part of the county you live and if the car is driven in the winter where salt is used on the roads....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Like Mystic says; check the dust seals for damage... if any visual damage, replace/rebuild them.
If any pistons are stuck I suggest you rebuild them. It isn't very difficult and doesn't take too much time when they are off the car already. How to check for a stuck piston: If you're having problems pushing one or more pistons back for the brake pad removal rebuild; the caliper. Good luck. - Michiel
'94 964 - Celebration 30 Jahre edition '06 997 - arctic silver with cocoa interior - sold '77 RoW 911 - black and still sexy - sold and I miss her '05 Audi A3 Sportback 1.9TDI (not a bad daily driver) - gone |
Thanks for the input. I'll inspect them soon.
68 911L |
Also look at the pads, if they're wearing unevenly could be due to a sticking piston or caliper hardware...also trashed dust seals (as mystic said) are usually a tipoff.
Rob Black 1983 911 SC Coupe |
Senior Member
Re: When to rebuild calipers?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Information Junky
how do you figure, supe?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
When it came down to my car, I figured if I had to ask, it was probably not a bad idea. For the price of the rebuild kits, it was worth the peace of mind. That may just be me.
1967 912 2.7 1977 MGB (bright yellow) 1985 Honda Spree Moped (great for towing rollerbladers) A flute without holes, is not a flute. A donut without a hole, is a Danish. |
the job is not trivial, but the parts are cheap.
For me, I'd say it's time when they start leaking brake fluid, and not before, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
ianc
Just got off the phone with Pelican and they say there is no rebuild kits for the rear caliper for the 911L same as a 1968 911S. How can this be? What's the diffrence between the front and rear caliper?
68 911L |
Senior Member
![]() ianc
Senior Member
Information Junky
brake fluid is hydrophilic . ..that does NOT mean that it some how collects water, carries it to the calipers, and then leaves it there . .. like a puddle. .. .somehow tough to flush. NOT AT ALL. Just flush the system with new brake fluid. The hydrophilic nature of the new ("dry") fliud will act like a dry sponge to any remaining "moist" brake fluid. Thing is, your not ever going to keep all the moisture out of the system. All you can do is be reasonable about it. (change the fluid) Else, I suppose you could rebuild them only in Arizona .. .and be certain not to breathe on them during the rebuild (you've seen what happens when you breathe on a mirror; haven't you?)
