ISpeed2day's Avatar
can I rekey ignition switch
Okay, all the locks on my car now match my keys except the ignition switch,
Can that be rekeyed?
Old 11-04-2006, 01:45 PM
ISpeed2day's Avatar
ttt
Old 11-04-2006, 06:39 PM
I was able to do this (or have it done anyhow) BUT it was a new ign. switch that I hadn't yet installed. It's a major pain to remove that switch and I wouldn't do it unless my switch failed. Since that R&R, I even went to the effort of installing a remote start button to minimize wear on the switch in the hope of never having to do the ign. switch project again.
Much easier to rekey the other lock cylinders to match the ign. switch key IMO.
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 11-04-2006, 09:26 PM
ISpeed2day's Avatar
getting the switch out isn't the hard part,
how did you get the lock cylinder out once the switch was out?
Old 11-05-2006, 04:43 AM
Nine9six's Avatar
Do you have the 101 projects book? I believe its described there.
Or maybe a search would do you some good.
Try it, you might like it.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-05-2006, 07:59 AM
I contacted my local Porsche dealer and they gave me the name of the locksmith they use, who happened to be mobile - he came to me.
There is information in 101 Projects on this that may just work for you.
Mark
'82 SC Targa (RIP)
Old 11-05-2006, 09:13 AM
ISpeed2day's Avatar
information on rekeying door locks does not help. Any other ideas?
Old 11-06-2006, 06:12 AM
Take it to a locksmith, there is a pin that needs to be drilled out, do it wrong and you wreck the tumbler. In fact I would say that it will probably be cheaper to have all your other locks changed to match your iginition as they all disassemble easily.
Robert
Currently Porsche less (but the wife has 2)
Old 11-06-2006, 07:02 AM
syncroid's Avatar
I have re-keyed at least 100 of these ignition lock cylinders. A little tricky but it can be done. PM me if you would like for me to do it for you. It takes about an hour.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 11-06-2006, 08:54 AM
