The wire IS pretty - and keeps the bolt out of your turbofan... and BTW - dig up the old threads on split-ring lock washers.... |
Yeah safety wire is more so loose bolts don't end up in places they shouldn't I understand.
JJ - you wore the dolphins? You are saying that despite all the terrific safety stuff (beefed up after disasters) there are critical fasteners, with procedures for tightening them to ensure they don't loosen, etc, which don't require safety wire? Does anything get safety wired on those boats?
Walt, yes but the were vertical (Ship Diver).
Wire are use on very few items (I'm going to look at the drawing package so I can sleep tonight...). Tab washer are more comment and a variety of Loctite. |
I just pulled the axles off my car last night. I'm dropping the engine and transmission and found the CV joints at the tranny were worn with almost no grease in them so rather than rebuild, I thought I'd just go with rebuilt axles. I ordered them from our host.
I didn't find any moon plates or lock washers. You can also see in the photos that there's no metal clips on the narrow side of the boots. I'm the second owner of my car. The prior owner had a shop in MD do a fair amount of work before I bought it in 2012. I guess they reassembled the axles without those clips. I did notice, particularly on the tranny side, that there's enough gunk in the hex heads of the bolts to prevent getting good purchase with the allen wrench. I was picking away at each one with an ice pick but found spraying brake cleaner in each one worked faster and better. http://forums.pelicanparts.com/uploa...1697026023.jpg |
IMO, you should find some replacement moon plates and lock washers. I've had CV joint bolts loosen up, so do everything the factory did to keep them tight. Plus blue Loctite.
I installed new moon washers, Schnorr lock washers and bolts. My SC was missing the moon washers as well. The best buy I was able to find was here: https://www.jbugs.com/product/87-5081.html
Good luck |
I got my rebuilt axles from our host. One of them had clearly been sold before, poorly packaged back up and returned. The protective plastic cap and mesh boot weren't attached at one end. I guess our host doesn't inspect returns before shipping them back out. I hate wasting time returning things.
Keep it or return it?http://forums.pelicanparts.com/uploa...1697229996.jpg |
People often have to return things after they unpackaged and discover that it doesn't fit right. BTDT.
If it doesn't look like it was actually used, I'd keep it. It's gonna be "used" soon enough, right? |
This amazing thread is absolutely overdue for a bump, and I need some help please. Following this thread and others, I decided to upgrade to the later Carrera axles on my '81SC.
To start, some info from the late, great Grady Clay from post #243: Quote:
In my case I decided to buy new billet transmission axle flanges from CMS, with their spacers since I have an LSD. And while I had everything apart, I installed new wheel bearings. All good there. HELP: New bearings are done, wheel hubs pressed back in, new transmission flanges installed, and 911.332.024.16 axles procured from our host (rebuilt GKN/Lobro, GKN part 300758.) Except... the axles are too short. Verified with Pelican that I received the correct axles, and that the GKN part numbers are correct for the application. These are not the Turbo axles. Obviously, I'm missing something. All input welcome! Pics of the new vs. old axles: http://forums.pelicanparts.com/uploa...1754473881.jpg http://forums.pelicanparts.com/uploa...1754473881.jpg http://forums.pelicanparts.com/uploa...1754473881.jpg http://forums.pelicanparts.com/uploa...1754473881.jpg |
Do you need to update the outboard hub for this conversation as well?
Maybe not the most helpful question, but I don't see it mentioned in your post and I do see it mentioned in Grady's old posts. |
EDIT: PET from '87- shows the same part number for the wheel hub as well on non-turbo cars. |
I'm not sure I see how you could have used a G50 axle, as it wouldn't mate to the 100mm 6xM8 transmission flanges. There were changes around '76 (by memory, it's all in this thread) to the 100mm CVs and flanges, and a change again to the 108mm with integrated stub axle sometime in 1986. |
Yeah, I have a G50 transmission. Originally I had a 901 and that was about the same width as the G50. A 915, if you have that, might be narrower. 20 mm too short sounds like a lot! Are you sure about that?? Have you looked here: https://forums.pelicanparts.com/porsche-911-technical-forum/596183-cv-axle-cross-reference.html The length of the late 108mm and the 100mm axles should almost the same. |
I'm going to piggyback a quick question onto this thread. My SC has a torn inner boot that I'm going to replace soon. I have a new boot. Does any of the hardware need to be replaced when R&Ring axles/CVs?
New schnorr washers might be prudent, but even new arent that great. If you want some lock washers thats really good, nord lock is the choice, but you need longer bolts for them. |
UPDATE: I would like to formally announce that I am a doofus!
A friend asked me if I'd pulled on each end of the axle to see if it needed to be expanded a little. The thought had crossed my mind, but I had no idea that these things expand like an accordion! The CV's were a bit compressed from the factory, and with a little pull they stretched right out. In they went, all torqued up, ready for a test drive! So it was my turn to be an idiot so someone else won't have to. Thanks for the input everyone SmileWavy With moon plates and Schnorr washers, just as Grady would want to see it: http://forums.pelicanparts.com/uploa...1754506280.jpg |
