oneblueyedog's Avatar
If I can rebuild an engine why not a ac compressor?
I've got a Performance Aire setup I installed 5 years ago. I've got low freon. The seal is leaking oil mist on the inside of the hood. It's blowing cool but not cold. I checked the sight glass and theres no floating ball in the window.
If the seal leaks, replace it right? I can't find anything on the web about the Seiko Seiki compresor on how to service it.
I want to replace the seal after evacuating my AC. I saw the seals available from NZ for 19#.
Also saw a clutch tool set.
Anybody DIY a compressor seal on a Seiko Seiki? Or any other type? It makes wasteful sense to replace a compressor because of a bad seal. That would be like replacing a new tire because of a bad Schrader valve.
Help please.
78SC coupe, Silver Metallic
Old 05-22-2005, 04:14 PM
3.2 CAB's Avatar
I have resealed and installed new bearings and other parts on a/c compressors in the past. Just have the proper tools, clutch/hub puller bearing puller various circlip pliers, and you should be able to do it f you can locate the correct parts. Go for it, what do you have to loose but some time and a small amount of $ if it goes south. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-22-2005, 04:35 PM
Last spring, I replaced the front seal on my Seiko Seiki PSV-170 from Performance Aire (obtained in 1987). I bought the front plate sealing kit, which included the shaft seal. After taking off the clutch, you see the front face with 6 or 8 machine screws holding it on. Remove those machine screws and a couple of circlips, and the front plate comes off. Clean up and reassemble with plenty of AC oil.
No special tools required.
Got the kits from California Auto Refrigeration Dist, Inc, 995 N. Enterprise St, Orange CA 92867, tel 714-997-2800, fax 714-997-5709, calaire@pacbell.net. Part numbers were MT2106 for the shaft seal-SS170, and MT2078 for the GAsket Kit SS170PSS. $20.22 including USPS shipping to VA.
I made no attempt to take the compressor down any further, and did not check for other overhaul kits.
Old 05-22-2005, 05:08 PM
Who is John Galt?
Rondinone's Avatar
I bought an entire rebuild kit for the York compressor from JC Whitless. It had every seal and gasket, and cost maybe ~20$.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 05-22-2005, 06:03 PM
What about a noisey compressor can that be easily fixed. It bangs when it runs. Is that a bearing?
Old 05-22-2005, 06:35 PM
Awesome. Thanks for the replies! I'll post the procedure when I tear into it.
Old 05-23-2005, 05:53 AM
QUOTE: No special tools required.
Brian, What tools did you use to do this job?
BTW, Your links helped me get the parts!
Thanks.
Old 05-27-2005, 01:08 PM
OneBluEyeDog,
What tools? Just like it says: No special tools required, unless you count snapring pliers. Small socket for the center bolt, phillips screwdriver for the front plate cap screws.
For sure, you do not need the special tool for removing the front seal, since you will be taking the front plate off. and will have direct access to it. It is really simple.
Old 05-27-2005, 03:59 PM
Senior Member
www.ackits.com
Did my compressor two years ago and it works fine with no leaks. Takes a special tool to pull the clutch and thats it. They sell the seals as well.
JoeA
Old 05-27-2005, 04:21 PM
