Todd Simpson's Avatar
Is my strut toast?
Boge strut with Bilstein insert.
Jacked up, when I grab the strut at the joint between the insert and strut (dust cover is off) I get knocking and noticeable play between the strut and the insert.
I know the insert is gone, but is the strut gone as well? Cap is tight.
Old 05-23-2005, 05:52 AM
trak ratt's Avatar
Most just find that the insert is bad. If original it’s not truly an insert so when the bushes go bad the strut rocks as you describe. In either case the only real way to tell is R&R the “guts”. Remember the bottom part of the strut is just a tub with the spindle attached. Everything else is replaced with the new strut “cartridge”.
Old 05-23-2005, 06:50 AM
Priced-out of Porsches.
mmastro's Avatar
THere is a teflon coated bearing sleeve that the insert rides in. When the teflon wears away, you get play in the strut. If you are changing the inserts, just change the bearing sleeves, too...your Bilsteins will be as good as new!
Mike
SoCal
Old 05-23-2005, 08:12 AM
OK, got everything apart, the play is coming from the screw cap.
Do you get a new cap with Bilstein inserts?
Old 05-23-2005, 05:11 PM
Friend of Warren
Yes it is a different cap from the Boge.
Kurt V
Old 05-23-2005, 06:21 PM
Slackerous Maximus
HardDrive's Avatar
Todd, was this difficult to do? I have to put Bilstein inserts in my Boge struts soon. Diffcult job? Any warnings?
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 05-23-2005, 06:57 PM
mmastro's Avatar
I'm sorry, I totally miread your post....I thought you had Bilstein struts......DOH!! I feel stupid.......8^)
Mike
SoCal
Old 05-23-2005, 07:55 PM
OK...the new bilstein inserts came with the cap at the top of the strut.
I've installed them and the play is gone. The insert in the cap had indeed gone bad.
Old 06-06-2005, 05:18 PM
