rick (guest)
Guest
Posts: n/a
WHEN I PRESS THE HORN I ONLY GET A CLICKING ,,,ANY HELP WOULD BE THANKFULL ,,RICK
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-11-2013, 01:12 AM
Where is the clicking coming from? If it's coming from a relay you may have a blow fuse, bad horn or broken wiring. Jump the horn relay and see if it sounds
- Kerry
Member 911 Anonymous
DRACO A5OG's Avatar
The horns sits in a very harsh environment, check to see if the connectors are loose or worse corroded away.
+1 click is from the relay in the fuse panel.
'85 Carrera Targa
PCA/POC
Old 08-11-2013, 11:54 AM
